Weak Image Transmission - Mavic Pro Zoom
2779 8 2021-9-1
fans2c3e4383
Flight distance : 132234 ft
Surely now there must be a fix for this issue of ‘Weak Image Transmission’ ? Seriously it’s so frustrating! I’ve a mavic pro zoom (2.5 yr old) flown around 25 times, never an issue until I updated last year and then the dreaded messages came up after 30-40mtr of flight. Weak image, loss of imagine, disconnected etc - so like many of us we hit the forums to find the fix. Seems this has happened to many people after an update - kind of rules out the drone is damaged theories.
Ok, so a yr has gone past and I’ve decided to try all the fixes mentioned.
1st off there was a new update , why not maybe DJI have fixed the bug.
Cut story short - No it didn’t help or fix anything.
So here is what I’ve tried so far!
Removed and Changed SD card
Reinstalled DJI Go4 and Assist 2
Refreshed the latest updates on drone, batteries and controller.
Rolled right back to bottom update version 1.3
Used custom settings in transmission , changed values , reset to auto
Reset all controller settings
Changed cables, used iPhone 8 and iPad mini 4
Both with latest iOS 14.7.1
AND IT STILL HAS NOT FIXED THE ISSUES!!!!
There is only one option left to try - FACTORY RESET!
Oh hold on, sorry forgot, DJI Kindly took this option away from the Mavic Pro users on Assist 2 BOOOOOO! Why? It means we can’t even reset to sell on etc , this is a very bad move from DJI , We NEED this option back please!!
It could be the Only option that Could actually fix this issue many of us are having after your updates :/
Please look into fixing this issue , as it’s an expensive loss for us loyal customers
If anyone knows the fix please share as I’ve had enough of trying :/
2021-9-1
DJI Stephen
Hello there. I am sorry to know that you are having this issue with your DJI drone. Kindly please check whether the remote controller's antennas are placed properly, you may refer to the below tutorial video. In addition kindly please fly the said DJI drone to another open field without interference to check there will be changes. Thank you.
2021-9-1
Montfrooij
Flight distance : 2560453 ft
Hi!
You might be better off posting your question in the 'products' section of this forum.
That is way more active.
Just create a new thread here : https://forum.dji.com/forum-129-1.html and select the right category / subcategory.
2021-9-1
DAFlys
Have you tried another location?   Some locations can have bad interference.
2021-9-1
fans2c3e4383
Montfrooij Posted at 9-1 23:11
Hi!
Cheers just done
2021-9-1
fans2c3e4383
DAFlys Posted at 9-1 23:38
Yes Arnold locations where I had no issues before and in fields in the middle of no where , over lakes , up mountains etc
No joy!
2021-9-1
fans2c3e4383
DJI Stephen Posted at 9-1 19:40
https://www.youtube.com/watch?v=P7M9JtfVwQE
Cheers have tried all of this to no avail
I’ve seen many posts with same issues and all happens after an update which makes it a DJI fault and not the drone - do DJI care? Nope :/
2021-9-1
Montfrooij
Hope you get it sorted out!
2021-9-2
Felix Le Chat
Flight distance : 1348 ft
Late response, I know, but some of us are STILL having problems with the "weak signal - please adjust antennas" problem. My Mav 2 Zoom transmission signal was rock-solid for three years - regardless of environment. While I've never sent her out on long-range flights (I prefer to keep the drone in plain VLOS sight), after a firmware update: the normally bullet-proof video signal started dropping out. Then the control signal did the same. This happens when the drone is only a matter of 50 feet away. Like everyone else: I've tried all the usual suggestions about interference/bluetooth and I-devices/ wiggling the antennas etc and... absolutely nothing. The signal is still useless which means a £1200 drone is also useless. If you want to factory re-set a Mav 2: you need to use the older version of the DJI Assistant 2 software: Version number: 1.1.2.573. This still has the factory reset option on the firmware upgrade tab. I honestly think that this is just about the only option left to try as the "support network" will just run you round in circles. Best of luck to any and all DJI CUSTOMERS who are having this crippling problem.
2022-8-29
