5. Dev mode -> select use dev options ->select usb debugging
6. usb cable connect PC and SC
7. SC : pop up -> asking Allow USB debugging->always allow select ->ok
(very very important,if this question is asked you'r Success , if not :failure )
8. sc : pop up-> asking use USB to -> MTP (transfer files) select
9. PC : Wait until the SC device is visible (smart controller or rm500)
12. PC: copy n paste below command to CMD, n Enter adb shell pm grant jp.co.c_lis.ccl.morelocale android.permission.CHANGE_CONFIGURATION
13. SC : go to more locale2 app ->select your language
14. PC CMD : if no devices error -> return 5, ->6.7.8.9... on and on
14-1. PC CMD : if no devices error ->reboot SC -> will be changed language
Finally : changed language ( korean)
DJi FLY language changed ( korean)
If you have trouble in setting,
Search the, Multilingual installation using more locale 2
** Android djigo4 may not support multi-language **(dji does not support multilingual only in Android version)
================= SC reset
If you want to return to the original state
SC->settiing->factory reset
================= c. you can enjoy n training FPV, with SC stick
1. SC setting->dji lab->control sticks compatibility select
2. intall freerider n Quardcopter Fx ...
3. launch simul -> setting -> controller or joystick select -> adjust the settings for you -> enjoy simul
4. If the 7-inch screen is uncomfortable, connect it to a large monitor with an HDMI cable.
I couldn't find a way to connect the liftoff game to SC. ( most famous FPV slmul in pc)
If you know how, please share
i want DJI support drivers(firmware) that allow Windows to recognize the SC as a game controller
(Recognizes SC only as a media device)
Hello there Farmer_mapo. Good day and thank you for sharing these very detailed information that you have created for this matter. Nicely done and thank you for your support.
DJI Stephen Posted at 9-2 21:17
Thanks for the replies and comments.
One more, C item has been added.
please suggest C's opinion to the development team (recognizes SC as a game controller)
It will contribute to DJI FPV sales and SC sales.
Farmer_mapo Posted at 9-3 04:49
Hi there Farmer_mapo. Thank you for the reply and you are very much welcome. I will forward these information to the designated DJI department for further evaluation. All significant suggestions will be implemented after the evaluation of the DJI Engineers. For the latest DJI Air 2S and DJI updates please stay tuned to our DJI official website at www.dji.com . Thank you.
Hi Farmer_mapo, nice guide is well done, I followed it step by step to see if I could set the language in Italian, at least to be able to have DJI Fly in Italian, but I failed when I launched the adb fastboot program and entered the string in the command line in CMD it always gave me error: no devices / emulators found, I tried several times and I also reset the SC but nothing, do you have any advice?
Marco_Roma Posted at 9-11 12:42
Although the step-by-step sequence is slightly different, the method of installing and using moreloale2 is the same on Android devices.
Some succeed and some fail, but I don't know why.
Find it on the internet and try again: Install more locales 2 on Android to use multiple languages.
* Keywords: Change Android language, morelocale2 add language ....
Farmer_mapo Posted at 9-11 18:03
Thanks to your guide and your advice I was able to set the language in Italian, now I finally have my Smart Contropller and DJI Fly in Italian, thank you very much
