calibrage nacelle/caméra / (Phantom 4 Advanced)
1014 2 2021-9-3
ELO203
Bonjour à tous,
Lors du calibrage nacelle/caméra via l'écran des carrés avec points bleux (DJI Assist. 2) à viser avec la caméra,
un écran ordi. incurvé (donc pas tout à fait plat) peut-il fausser voire empêcher le calibrage de se faire correctement ?
Je vous remercie vivement par avance pour votre réponse.
Bien à vous,
AD
2021-9-3
Montfrooij
Flight distance : 2560453 ft
Hi!
You might be better off posting your question in the 'products' section of this forum.
That is way more active.
Just create a new thread here : https://forum.dji.com/forum-129-1.html and select the right category / subcategory.
2021-9-5
DJI Paladin
Flight distance : 318 ft
Hi there. I was able to translate your message and it seems that you are having some issues when calibrating your Vision Sensor on the DJI Assistant 2 software and we're sorry about the issue. Can you please confirm if the said unit experience a hard landing before? Also, Kindly please try to use a monitor display of 14 inches or bigger is recommended for the calibration. Please set the display’s resolution to the recommended default value. ( Usually, the 14-inch display’s resolution should be set at 1366*768 or 1440*900. The 17-inch display’s resolution: 1366*768 or 1280*720. The 19-inch display’s resolution: 1366*768 or 1440*900. The 22-inch display’s resolution: 1680*1050 or 1920*1080. The 24-inch display’s resolution: 1920*1080 or 1920*1200.). Please keep us posted. Thank you!
2021-9-5
