Huginn Kenningar
Flight distance : 49635259 ft
Air2S is the drone with the best connection atm due to it having 4 antennas on the drone... the problem is not the drone, is the CE regulation instead.
CE mode is a crap, expect roughly the same performance of the Mini 2, a bit better actually, but more or less the same. The main problem in CE mode is that the 5.8Ghz band is not even usable due to it's low power restrictions, so you'll always fly in 2.4Ghz, which has a lot o interference in populated areas.
The cheapest and best solution is to force FCC mode using the DH program. FCC increases the power in the 2.4Ghz band from 100mW (20dBm) to 400mW (26dBm) and in the 5.8Ghz band from 25mW (14dBm) to 400mW (26dBm). With FCC mode activated, the dual band/multichannel will be usable, and you'll have solid 4-5 bar connection no matter what under 1Km and excellent performance from there on, reaching way beyond it's battery limitation in uninterferenced environment.
So in resume, in FCC mode you have x4 the power in 2.4Ghz and x16 the power on 5.8Ghz... So yep, the best accessory you'll ever buy for your drone.
FCC mode, dual band on, multichannel on, airplane mode on the controller... and you'll never have connection problems again, it's almost like flying with 4G connection XD
