ZachD
Hello, any help or advice would be much appreciated.
Please see the image above. My Mavic Pro 2 experienced a crash from approximately 7ft off the ground. Everything is in working order except for the drone's ability to pan vertically and horizontally using the controller. During startup, the gimbal arm rotates all around as normal (does not seem to be broken) and then the UI states to remove the gimbal clip because the gimbal motor load is too high (it can't move in all ways as it wants to). I believe the problem has to be due to the circled portion in the above picture. It seems like if I could seat that joint correctly and pop it back in to place I would have no problems.
I have not tried to force it too hard for fear of worsening the damage. Does anyone have any experience or advice on how to fix this?
Thank you again for any help or advice.
