Hi! New here!
Could anyone kindly suggest where I could possibly get a replacemnet lower gimbal plate? At this stage all I've been told is to buy the entire 4K camera and gimbal. This is pushing it as all I need is the plate as my camera is fine. Cheers!
what is the lower gimble plate exactly? i may be able to give it to you as i have a crashed gimble/camera that i no longer use. the part you are looking for may be is still good on my unit and i ll be happy to give you it. rayrokni@gmail.com
rayrokni Posted at 2015-7-29 01:07
what is the lower gimble plate exactly? i may be able to give it to you as i have a crashed gimble/c ...
Hi there Ray,
Thanks for the response. The part I'm looking for is the plate with the four holes in the corners that the dampeners connect to. The top plate can be bought new but I can't find the one I need. It is the free floating part.
It sounds like you're referring to the top part of the gimbal -- pictured here:
www.PhantomHelp.com
Find the latest must-haves, fixes, mods, how-tos, guides, and accessories for your Phantom.
Phantoms in stock and ready to ship worldwide! (see availability)
Thanks for the response. The part I'm looking for is the plate with the four holes ...
so you are not talking about the top plate which screws in the shell, you are talking about the bottom plate that attaches to the top plate via the four dampeners, correct?
When i get home i will look and if not damaged i will happily give it to you since i bought another P3P and i am hoping i will not make the same mistake again, hopefully i will not need it!! i will let you know today sometime. are you in the USA? for shipping purposes, iask!
