DAFlys
Flight distance : 312090263 ft
From https://dronexl.co/2021/09/13/dji-mavic-3-rumors-update-china/
- These renderings are based on actual photos of the M3, although the renderings are not accurate in their size, dimensions, and overall design.
- The DJI Mavic 3 will have a dual-lens setup
- You can switch between the lenses on the fly (pun intended)
- The specs are shown on the camera. The top lens is a seven-times (7x) optical zoom lens. The other lens is marked “F/2.8 EQV 24”. The top left corner of the camera shows an ‘H’ to indicate that it was developed in partnership with Hasselblad. Note: eventhough it doesn’t say so explicitly, we still expect the camera to have a variable aperture ranging from at least f/2.8 – f/11.
- The DJI Mavic 3 will come in two versions, the more expensive one will be equipped with a 1TB SSD drive (solid-state drive) and ProRes video recording capabilities. The lower-end drone will come without the 1TB SSD onboard.
- Battery life (and/or flight time) is expected to be 45 minutes.
- The drone will come with a new remote controller with a built-in screen. The design is expected to be similar to the remote controller from the DJI Air 2S. The hardware will have been upgraded and will offer O3 (OcuSync 3.0) for the DJI Mavic 3.
- The DJI Mavic 3 is expected to be somewhat larger than the outgoing DJI Mavic 2 Pro/Zoom.
- The DJI Mavic 3 is expected to be released in November. However, keep in mind that DJI tends to change plans at the last moment as we have seen time and time again.
- More than one factory will be involved in the production of the M3.
