DJI Wanda
Hello, there. Would you please check the following things?
1. Ensure that the aircraft mode is normal, i.e., the GPS signal is strong and the aircraft is in non-ATTI mode.
2. Check the propellers and the state of the motors. Check whether any motor rotates abnormally when the propellers are not mounted.
3. Confirm that there is no magnetic interference. It is recommended to place the aircraft on level ground for IMU calibration and compass calibration.
4. Check whether the control stick is being pushed. If the stick movement is offset, the remote controller should be calibrated.
5. If the problem persists, please shoot a video for us. |
