Phantom 2 Vision+
700 4 2021-9-27
Alanfro55
Yeah, I know, I have an old drone but I've lost the binding on my remote to drone/camera. When trying to reset, it reports : "Wi-Fi Repeater Connection Failed"
Seems like I cannot get beyond this point in an endless loop. Any suggestions from you experienced folks?
2021-9-27
Alanfro55
That's actually the camera that won't bind using the DJI app. The remote still works but we're blind!
2021-9-27
Mark The Droner
Flight distance : 2917 ft
Are you sure you're binding correctly?  Are you using the MAC address from the wifi module?
IF so, sounds like your Range Extender failed?  But that's rare.  You can check it easily with a free wifi analyzer app.  See if it is transmitting wifi.  Then do the same with your drone.
When all is said and done and the binding is perfect, you still likely won't have FPV because the NAND likely needs to be flashed, but that's a different problem.
Good luck.
2021-10-1
Labroides
Flight distance : 9991457 ft
The P2V+ is a stone age lump of junk, even if it worked properly.
Do yourself a favour, save the hassle and get something more modern and 10 times better.
2021-10-1
Mark The Droner
2021-10-2
