What does mean « (Global Excluding BR & JP)«  when shipping
6995 16 2021-9-28
djiuser_1VR3JlDtX5mq
Flight distance : 205738 ft
I sent my drone for a repair and I received this message from DJI « DJI Mini 2 Aircraft Module (Including Gimbal & Propellers) (Global Excluding BR & JP)(DJI Care) »
I understand they will send me a new drone but what does mean « global excluding BR & JP » ?  What is excluded ?
Thanks form your help.
2021-9-28
DJI Diana
Flight distance : 2408 ft
Hi there, thank you for reaching DJI Forum. I was able to pull up the case number using your DJI Forum details. Regarding the inquiry, it will be the version of the unit you have. Please be advised that the DJI Care refresh service plan covers the aircraft × 1, gimbal × 1, camera × 1, propellers (pair) × 2, and battery × 1 since you have the DJI Mini 2. Thank you.
2021-9-28
DJI Diana Posted at 9-28 16:18
Wow, great customer services with DJI.  I sent my dammaged drone yesterday and today I received a UPS tracking number for the new one.  Furthermore  I got this quick answer to  my question.
Thanks Diana
2021-9-28
DJI Natalia
djiuser_1VR3JlDtX5mq Posted at 9-28 16:28
Thanks Diana
You're most welcome. Should there be any other concerns, please feel free to let us know.
2021-9-29
Jaybro130
Flight distance : 7545591 ft
DJI Diana Posted at 2021-9-28 16:18
DJI is sending me a new unit (new serial # under warranty). And it says (Global excluding JP). What does the “JP” mean? Case # CAS-8121573-P9H1L2. Will my care refresh switch over to the new drone?
2022-1-25
DJI Diana
Jaybro130 Posted at 1-25 12:39
Hi Jaybro130. Thank you for reaching DJI Forum regarding your inquiry. You may kindly disregard the "Global excluding JP" indicated as it is only a description or the version of the DJI Mini 2 that you will received. Also, I was able to check the serial number of the replacement unit and the service plan was already been transferred on the replacement drone.
2022-1-25
Jaybro130
DJI Diana Posted at 1-25 16:10
Thank you very much for replying!  As I understand it, JP=Japan as they have a restricted type of drone.
2022-1-26
DJI Susan
Jaybro130 Posted at 1-26 05:05
JP is Japan and they have their version. Hope you receive the package back soon. Any further questions, please feel free to ask.
2022-1-26
djiuser_NdopdJclnZIa
If JP means Japan.does BR mean Brittan?
2022-4-4
DJI Susan Posted at 1-26 23:03
2022-4-4
DJI Wanda
djiuser_NdopdJclnZIa Posted at 4-4 03:26
Hello, there. Thanks for your inquiry. JP means Japan while BR represents Brazil.
2022-4-4
djiuser_u95SOBIEgeaj
I received my replacement in closed box in a plastic sealed wrap. It doesnt say whats inside other than the photo of the drone. What is included in this package? I was thinking of giving it to my nephew as a christmas present but dint know of the its a conplete package.
2022-11-11
DJI Diana
djiuser_u95SOBIEgeaj Posted at 11-11 00:01
Hi, there. Thank you for reaching DJI forum regarding the inquiry. Please be advised that I was able to check the previous case using your DJI Forum details and based on what I can see, the case is from a couple of months ago. May I confirm if it's regarding your DJI Mini 2? Please be advised that I also sent you a PM to verify and check some information. Please check. Thank you.
2022-11-11
djiuser_oTH4XMb7Cdx5
Flight distance : 42844 ft
Hi there,
Wondered if anyone knows what
Contents: DJI mini 3 Pro Aircraft & Gimbal Module (GL, Excl. BR) means just the bit in the brackets iam in uk so want to make sure I've put all the bits iam suppose to in the box before it's picked up
Thankyou in advance
2023-11-24
DJI Wanda
djiuser_oTH4XMb7Cdx5 Posted at 11-24 05:01
Hi there,
Hello, there. Do you want to confirm whether it is the right version for the UK or anything else?
2023-11-24
Hi there
Just if it ment what the letters in the bracket mean, I bought it in uk so was just making sure DJI sent right label for DHL to pick up and thought br was to put battery in but think it means something else
Thankyou in advance
2023-11-25
DJI Susan
djiuser_oTH4XMb7Cdx5 Posted at 11-25 05:22
Hi there
Thankyou in advance
Hi there, that BR does not mean the battery in this content. Regarding your case, if the battery is not severely damaged, you can send it along with the drone.
If the battery got severely damaged, it would be dangerous to ship. Then please take pictures of the battery as well as the battery serial number, send the pictures to us via email at support@dji.com with the case number, we will follow it up.
2023-11-25
