How do I fix the drifting issues with the Ronin S?
561 0 2021-9-30
djiuser_NIgQgDv2EHpU
Flight distance : 75548 ft
I've tried joystick calibration.
I've tried regular calibration (on a flat surface).
I've tried offset calibration.
I've made sure the camera's fully balanced and tested the balance.
I know it's a joystick issue, because when I disable the Pan movement in CH3 on the mode that I'm using (M1), the drifting stops immediately.
The joystick does seem to be very very slightly pointing to the right, but it does however, drift right and left. I would've thought there was a way to fix it or work around it. I think I will have to send it to DJI to replace the joystick or something.
It doesn't drift after I turn it on or calibrate it, but it does start to drift after I move the joystick. And it drifts a lot when I use Active Track.
2021-9-30
