about point of interest poi in air2s...please somebody help
1714 6 2021-9-30
subbassline7
Flight distance : 75 ft
Greece
im in to lightpaint with drones at night and when  i saw  the air2s i wanted  to buy it so  i searched about this feauture and could not find anyone talking about it...so when you fly at night in total darkness and you want to create a halo over your subject  the point of interest  cant see the subject you really fly around so if you swipe with your hand on your phone  it will not track the subject...so i saw in mavic pro has this feature that you can go right above your subject put a jps point and then the drone can circle around it without have to visually see where is circling...can you do that on the air2s???if somebody knows it will mean a lot guys
2021-9-30
videoeditman
Flight distance : 6713271 ft
I believe you mean waypoints, the Air 2s does not have that function.
2021-10-1
jwp721
Flight distance : 332822 ft
Haven’t tried it…but couldn’t you use a dim flashlight to illuminate the top of your subject so that Air2s can get a subject lock?  Since you are using a  dslr on a tripod the additional light probably wouldn’t impact your final image….
Btw..  I have seen images like you describe taken with the Air2s so it is possible somehow.
2021-10-1
subbassline7
Greece
videoeditman Posted at 10-1 08:21
not waypoints, points of interest there was this function that it would take a single point and circle around it go to 5:45
2021-10-2
subbassline7
Greece
jwp721 Posted at 10-1 10:40
well if i have an old ruin castle that you cant go on the top of it or some old buildings that there is no accesability to the roof what you do???check this video at 5:45
2021-10-2
FB: GeoDrone4K
Flight distance : 2676129 ft
Romania
Yes, we did this...You go with the Air2S above subject with the landing light ON...fix the POI on it...then start taking easy the drone out, until appears a tracking based on GPS...It will make your circles around the POI as based on estimated GPS instead of image tracking. Don't forget to disable the sensors, as in night the flash from the drone lights will give false readings of obstacles and you cannot disable the lights (Bad, DJI, bad !)
2021-10-20
subbassline7
Greece
FB: GeoDrone4K Posted at 10-20 00:47
thank u so much
2021-10-21
