problpme de connection
218 1 2021-10-3
Steve Tinguely
Switzerland
Bonjour,
Je viens de recevoir mon Mavic pro en retour de réparation (pour un problème de surcharge de caméra) .
Je n'arrive plus à connecter ma télécommande au drone , j'ai essayer de scaner le code qu sur une des branche du drone mais il ne tourve pas le wifi du drone...
que pui-je faire.
Merci
Steve
2021-10-3
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're deeply sorry for the trouble that this has caused. Can you please try to download the DJI Assistant 2 software on your computer and please make sure that both aircraft and controller are using the most latest firmware and check if the issue persists? You may refer to the link below for you to download the said software. Please keep us posted. Thank you.
https://www.dji.com/downloads/softwares/assistant-dji-2
2021-10-3
