Lost "signal" from camera ...
1630 28 2015-7-30
w1der
Sweden
So ... I lost the signal from my camera.
Happened the first time the other day ... Lost the signal in between a change of battery.
The camera feed was on when I landed but as soon as I rebooted the bird there was nothing!
Then the day after it worked again.
Today it worked as I turned the inspire on doing some tests with different settings (no camera settings).
But after restarting the bird it was gone.
Note ... all the time my Inspire resting on the living room table (no flight).
As it comes and goes this indicates something is "loose" ... but as this happens when the bird isn´t in motion that tells me it´s more of a bug.
I can control the gimbal and I can take a picture ... the file is generated (the camera works).
I can not preview the pictures through the app.
I recall others having this problem earlier.
How was it solved?
2015-7-30
PeteGould
Haven't seen that problem here, so I'm wondering if it is indeed an intermittent hardware failure with your system.
2015-7-30
dundee
Flight distance : 33550 ft
Thailand
Hmmm, maybe check the gimble contacts. Or that black rubber seal.
2015-7-30
Mountnman
Check to see if the fan on the camera has stopped when you loose signal and let us know what you find please.
I have similar problem and find that the video signal stops when the fan stops on my camera.
2015-7-30
retret66
Philippines
Mountnman Posted at 2015-7-30 22:44
Check to see if the fan on the camera has stopped when you loose signal and let us know what you fin ...
I have this problem now and the fan is working on camera..I think there is a major bug on the new firmware and the camera..everything works except no video feed, when I change the position of the camera from dark places to brighter subject, the ISO and shutter speed is reading it and changing, so I know the camera works..But now, you cannot update the firmware it makes a long beep noise after few beeps..everything still works and it will fly but just no video..I read somewhere its an issue with video module and could be related to hardware so mine is useless for video now..
I checked the hidden logs on the memory card and yes I see this "No Device Found" everytime...and the firmware update always fails
2015-7-30
w1der
Sweden
Are you suggesting that the camera is over heating?
This is not the problem in this case (I can take pictures, just no image in the "view finder" on the pilot app) ... and the fan is spinning just fine.
2015-7-31
w1der
Sweden
dundee Posted at 2015-7-30 19:57
Is this what you are reffering to ?
I took them out and reattached them ... no luck!
What is the "rubber thingy" ?
2015-7-31
w1der
Sweden
This one ?
Not sure what to look for !?
2015-7-31
dundee
Thailand
w1der Posted at 2015-7-31 17:35
This one ?
Yes that black round rubber with the little rubber balls around.
Also clean those contacts with some contact spray. (Camera and Gimble side)
2015-7-31
w1der
Sweden
dundee Posted at 2015-7-31 17:54
Also clean those contacts with so ...
Yea ... OK ...
I need to get some of that !
2015-7-31
w1der
Sweden
So ... I tried cleaning the contacts ... no luck.
Now the problem seems to be constant ... I guess I will get use of the warranty then.
2015-7-31
dundee
Thailand
w1der Posted at 2015-7-31 23:52
Now the problem seems to be constant ... I gue ...
Camera ventilator maybe
2015-7-31
w1der
Sweden
dundee Posted at 2015-7-31 23:58
Ventilator ... would you care to explain that more ?
2015-7-31
dundee
Thailand
w1der Posted at 2015-8-1 00:22
is the camera ventilator (cooler) working
2015-7-31
w1der
Sweden
dundee Posted at 2015-8-1 02:23
The fan ?
Yes ... and the problem is instant ... as soon as I turn the unit on.
I emailed the European support in Germany to see what they think about the problem .
2015-7-31
GB44
Flight distance : 343848 ft
Wilder,  Have you checked the pins of the gimbal on the aircraft - the part that the camera pushes up into and rotates to lock.  These can become slightly mis-aligned.
2015-7-31
w1der
Sweden
GB44 Posted at 2015-8-1 02:28
Wilder,  Have you checked the pins of the gimbal on the aircraft - the part that the camera pushes u ...
Yea ... they look fine ...
2015-7-31
dundee
Thailand
you have 2th remote ?
2015-7-31
w1der
Sweden
dundee Posted at 2015-8-1 02:36
No ... only 1 ... Only 1 of everything except batteries ... so not able to exclude anything really ...
2015-7-31
dundee
Thailand
Check settings, calibrate IMU
2015-7-31
dundee
Thailand
Did you change SD Card ?
2015-7-31
w1der
Sweden
So ... I moved my bird from a desk to the living room table ... and now the camera works ...
So I can´t really look for "triggers" more than what possibly could make it not to work again.
2015-7-31
w1der
Sweden
w1der Posted at 2015-8-1 02:55
So I c ...
Well ...
Turning it off and on again ... made the view finder go black ...
So ... trying the IMU thing anyways ... don´t think that it´s gonna work ... but it´s free to try!
2015-7-31
houston
Flight distance : 21241217 ft
I have had this happen a few times. Just turning it off and back on fixed it for me. The other day there was also "NO SIGNAL" and then it just popped up. It has never happened during flight though.
2015-7-31
retret66
Philippines
look here also..
http://forum.dji.com/thread-24640-1-1.html
its a defective product..everything works except the video feed..the pictures even though it is black on the APP but if you view the memory card pics via a computer or download them locally on your tablet, you can view them fine..
2015-7-31
w1der
Sweden
retret66 Posted at 2015-8-1 15:29
look here also..
Have you been in contact with DJI support ?
2015-7-31
retret66
Philippines
w1der Posted at 2015-8-1 15:57
Yes and it's worse than a horror movie!!!
Also, when I download a recorded video(even it is black) from the camera to the tablet via the APP, the speed is only 578KB/sec..So that is the issue...But then, even if you download the file locally, you still cant see the video...But I can view it fine on the laptop..
Here is an identical issue which he says DJI change the flight controller..
http://www.capedigital.com/journal/inspire-1-grounded
Update:
DJI site exchange policy shows if the unit is defective, but they are not willing to exchange my lemon unit..Now I open a dipute with paypal and possibly via American Express..I dont want a repair, I want an exchange since I wasted a planned aereal photgraphy meet and wasted a vacation for the sole purpose of my project..
2015-8-1
akdebwinkelman
Hi
I'm recently having similar problems...did you get this problem resolved?
thanks
Deb
2015-8-3
w1der
Sweden
akdebwinkelman Posted at 2015-8-4 01:58
Hi
thanks
DJI support team in Germany got my email after office hours on Friday and answered the following Monday. They want me to send my gear in ... and attached the RMA forms to use.
No suggestions at all from them on what to try first.
As I understand there is a "general problem" so I am happy to send it in and get it fixed.
Stated turn around time for professional 10-15 work days ... and for hobbyist 20-25 days.
This "first season" was only practice for me any ways ...
I´m happy as long as any flaws is discovered and fixed under warranty ...
But a bit bummed out as I would have wanted more video material to work with during the winter as I need to practice to edit also! Most material I have so far is a bit "jumpy" (pilot error) and I was just starting to get a hang of it.
With a bit of luck the winter wont be to cold ...
I will not send it directly to DJI though ... I will first adress the retailer that I bought my I1 from.
2015-8-4
