NEW DJI FLY 1.4.12
12Next >
7944 73 2021-10-8
Niknik
Flight distance : 1595640 ft
Greece
New DJI FLY 1.4.12(1386)
https://service-adhoc.dji.com/do ... 2-b4ab-9cf977d77309
2021-10-8
JJB*
Flight distance : 12225059 ft
and...any flight flown already with .12 ?
2021-10-8
Niknik
Greece
Yes everything ok
The only new thing is this
2021-10-8
GeorgeFoxCinematography
Flight distance : 17520892 ft
Niknik Posted at 10-8 02:19
Yes everything ok
[view_image]
Which mobile device you use?
Thanks,
George
2021-10-8
Niknik
Greece
GeorgeFoxCinematography Posted at 10-8 02:50
Thanks,
Galaxy Note 9
2021-10-8
videoeditman
Flight distance : 6713271 ft
This is not on the DJI website, where did it come from? Are we now Beta testers on their software releases?
2021-10-8
Niknik
Greece
videoeditman Posted at 10-8 04:18
Yes it is. Check the link in my post
2021-10-8
DowntownRDB
Flight distance : 1722 ft
Still shows as V1.4.8 but when you download you get V1.4.12.
2021-10-8
a1r_m0ses_b
Flight distance : 5922349 ft
Greece
I think that another new feature is the live streaming option in the top of transmission menu.
2021-10-8
DAFlys
Thanks for sharing.
2021-10-9
George GR
Flight distance : 2990653 ft
Greece
2021-10-9
SjK_oldman
Flight distance : 73583045 ft
The home point location is Jacked up bad.  Surely, I am not the only one?
2021-10-9
fans3f55c2ef
Flight distance : 568442 ft
I am waiting until it has more time to be tested and used by others because the previous app version caused my S21 to go black screen while flying, so I went to a previous version.
2021-10-9
JohnDG
Flight distance : 1097270 ft
Malaysia
SjK_oldman Posted at 10-9 15:41
nope. That is a problem for all of us.
The homepoint keeps hiding underneath the triangle drone icon. Turning the drone on it's side gets it jumping around. For the mini 2, a lesser problem is that you can't change colors of the frontled.
But the homepoint is very handy when you want to find out where the drone is pointing at.
2021-10-10
djiuser_u7Tyyi4TvSN1
Do NOT install, my battery capacity didn't go down, custom stick steering doesn't work, front light changing doesn't work... almost crashed... back to 1.4.8! Fortunately a friend still had the apk!
2021-10-10
Niknik
Greece
AND THE SECOND UPDATE IS LIVE STREAM
2021-10-11
sduck
Flight distance : 4315098 ft
When will the iOS version be released?
2021-10-11
videoeditman
Doesn't sound like a step forward, DJI we don't want to mess up working functions to add new ones.
2021-10-11
arizona mavic flyer
Flight distance : 1059072 ft
videoeditman Posted at 10-11 13:12
There are some sloppy display issues, but I've used the map instead of the compass and it works fine for finding my way home. RTH works fine too. I haven't seen the altitude error, but by all reports the drone lands properly. This version seems to have better range with Air 2S and the Smart Controller, so that's a positive. I flew for several hours with no blackouts, the maps worked fine for orienting the drone to my position. DJI should never have let this one out without adequate testing, but they are no better or worse  than Apple, Microsoft, Adobe or many others in that respect. It flys well, I can live without the compass until DJI fixes the glitch.
2021-10-11
vodanh11791
Vietnam
I had updated to version 1.4.12 but there is a problem with the app's compass, it prevents me from determining the direction of the pilot and the plane. Hope the company fixes this compass error soon. I'm using samsung s10.
2021-10-12
KlooGee
Flight distance : 16783757 ft
vodanh11791 Posted at 10-12 04:56
I have always found the map view to be way more useful.  I've never understood why people use the compass display instead.
2021-10-12
vodanh11791
Vietnam
KlooGee Posted at 10-12 05:54
Using the compass to determine the direction of aircraft control helps to transmit better waves and easily control the aircraft to return without looking at the map.
2021-10-12
djiuser_lwTqLU7tusoG
Slovakia
It seems DJI has just released the 1.4.12 build 1410, has anyone tried it yet. Perhaps they fixed the compass - home point issue.
It's available on the old download links and here also: https://www.dji.com/sk/mini-2/downloads .
Not on Play store though, seems APK mirror still has 1386 (pushed on Oct-11): https://www.apkmirror.com/apk/dji-technology-co-ltd/dji-fly/
2021-10-12
Niknik
Greece
2021-10-12
Mobilehomer
Flight distance : 18135846 ft
djiuser_lwTqLU7tusoG Posted at 10-12 07:56
Just came in from trying it out. Everything is as it should be. The compass is correct. The front LED control is back. The streaming option is there. Distance is a little better than before. ZERO problems. I had to sign in, then set unit measurement. The flight records also show up under "Profile" immediately, they were taking a few minutes.
Now, DJI - LEAVE IT ALONE!!!!
2021-10-12
Niknik
Greece
2021-10-12
fans1adbdd02
Why would I want to take a chance of updating , when my done is fine? Seems kind of silly to take a chance of screwing it up with a update that I'm not getting much out of.
2021-10-12
vodanh11791
Vietnam
Version 1.4.12 (1410) has optimized the camera view according to the installed image ratio 3:2 or 16:9 on the phone screen.
2021-10-12
djiuser_HMMz4blPxtkN
Flight distance : 11649029 ft
Brazil
Is IOS already available?
2021-10-13
Niknik
Greece
NO IT IS NOT FOR NOW
2021-10-13
KlooGee
vodanh11791 Posted at 10-12 06:16
Different strokes for different folks I guess…
With OcuSync, I don’t have control link issues so pointing roughly in the right direction is always more than good enough of a signal.  If I don’t know roughly where my drone is in the sky without looking at a screen, I’ve become situationally unaware and have become a safety risk.   Also, if I were to get disoriented, the map has a red line on it for the shortest path back home.
Not to mention all of the additional visual information available to help with situational awareness.  Am I over the road?  Am I over the building?  Have I reached the tree line yet?  Etc, etc...
2021-10-13
Niknik
Greece
KlooGee Posted at 10-13 13:58
That's exactly what I do. I never use the compass but I have the map and visually know where I am.
2021-10-13
Hrodnand
Flight distance : 2972293 ft
Romania
Have they completely removed the option to update through the app internally or it just takes some time until the update appears there as well?
2021-10-14
Niknik
Greece
Hrodnand Posted at 10-14 08:24
I think it takes some time to show up automatically inside the DJI FLY app
2021-10-14
Monkey007
Flight distance : 73775046 ft
Just  had 2 flights of the Mini2 with 1.4.12 (1410) on the Smart Controller; everything works fine. Compass is working correctly, as it also did on 1.4.8.
2021-10-14
Niknik
Greece
Monkey007 Posted at 10-14 15:12
Yes, it works flawlessly. Today we have and a new firmware
2021-10-14
Wgander
Flight distance : 1195853 ft
Can I fly Mavic Air 2 with DJI Go 4? I use that with my Spark and Android phone and iPad, just got a second hand Air 2 with no instructions.
2021-10-14
AlexanderK
Flight distance : 2023829 ft
Really, how hard is it to check for yourself on the DJI site?
2021-10-14
virtual
Flight distance : 4897142 ft
Czechia
My 1.4.8 app sais that is up to date as well...
2021-10-15
Niknik
Greece
And Another one
2021-10-15
12Next >
