JJB*
Flight distance : 12401030 ft
Hi,
3 Flights using 1.4.12 on Android, on my Air and Mini2.
See the too long video.
Compass / attitide indicator useless.
In the video
25 secs > HP is right to the drone, indicates forward!
25 secs > flying away and blue dot + HP circling....(uh?)
3m22s > Blue dot + HP in the center now, distance out = 925 meter...
5m47s > Looks if craft is above HP dots to the outer ring.
9m58s > Arrow on dot now green! and later again blue (what does green means?)
12m43 > Dots on the outerring, but at wrong position....
Next i uses my other device with version 1.4.8. and no problem at all
AND
The flightlog.txt are not in a FLIGHTRECORD map, maps are fewer than on .8
Not sure but log is now in a "flightrecord_db_0.0.1.db, this file was synced at the other device....DateTime mark correct to the time of flying...
Does this mean that from now on all flights are really unreadable ??
Can other v1.4.12 users check their DJI/dji.go.v5/ for sub maps ? map FLIGHTRECORDS there??
cheers
JJB
