Why don’t turn off on a crash?
729 7 2021-10-9
rodrigo_sclosa
Brazil
Hi people,
I have a DJI FPV drone and i was using it about 4 months, until last wednesday… I have a simples freeze frame exactly the moment that i was passing by an metal arc and i lost the control and crashes into the arc…
It was a simple crash, i was expecting  that could broke the arms… But after the crash, the drone got crazy on by downside, got full throtle and I cant turn it off… This strange behavior has damaged a lot of the drone, because the front motors has broken from arms and hits everything on the drone shell, and has taken off the bottom sensors board with entire shell and flat cable… So, I only was able to turn it off by looking into the goggles, putting it on Manual mode and switching it off by the swithc off motor functions from configuration menu of the controller..
But it was so scary and unsafe the drone being on that behavior about 3 minutes and it cant turn off!!
So, why the drone dont turned himself off after the crash? It was much more secure and safelly!
What should I do now with this dammaged drone??
Thanks!
2021-10-9
Max90payneFPV
Flight distance : 2832844 ft
Hello !!
If the drone was in manual mode, the motors must be turned off manually !! It says in the manual how to do it !!!
2021-10-9
DJI Paladin
Flight distance : 318 ft
Hi, thank you for reaching out. We're sorry for the unpleasant experience. In this kind of situation, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support. Thank you for your understanding and support.
2021-10-10
rodrigo_sclosa
Brazil
DJI Paladin Posted at 10-10 01:46
Thanks!
I'm from Brazil.. What should I do?
2021-10-11
Whoreable
Flight distance : 1775299 ft
Bad idea to auto cut motors on impact, you could drop the drone in water or off a cliff, much better to master manual mode or normal with knowing how to turn off csc when needed.
2021-10-11
rodrigo_sclosa
Brazil
Whoreable Posted at 10-11 21:40
But the drone falling upside down and being accelerated alone with throttle at maximum is a bad idea...
I've been flying FPV drones for over 4 years with Betaflight and other software... And they all automatically shut down in case of a strong crash and upside-down fall...
It's a matter of security, not convenience...
Better for the drone to fall into the water turned off, than fall on a person, a child or a dangerous place like chemical or flammable tanks and you can't turn it off, as was my case, where I spent almost 2 minutes trying to do it he turned off and he didn't obey... I had to reconfigure through the glasses menu the option to turn off the motors manually, after that it turned off...
2021-10-12
DJI Paladin
rodrigo_sclosa Posted at 10-11 20:58
Thanks!
You're welcome. Kindly please access the link above (https://www.dji.com/support) Have a great day ahead.
2021-10-14
Visual Air
Flight distance : 2710115 ft
Sorry for your loss. What are the red mounts by the gimbal?
2021-10-14
