Vertical lines on DJI Mini 2 photos
590 10 2021-10-10
Katedrone
Flight distance : 74390 ft
Vertical lines apear in my shots when I take them in panorama mode. The example I am showing is a single photo that was taked as part of a panorama. The line is most visable in the sky. I was wondering if there is a way to fix this from happening. And if anyone knows a good way to hide the line in Photoshop because these lines have ruined some good pictures. Thank you.
Vertical line example
2021-10-10
DJI Stephen
Hello there Katedrone. I am sorry for the trouble this has caused and thank you for reaching out. Before experiencing this issue was there a hard landing or a crash that happened before on your DJI Mini 2? In addition I hope that our fellow DJI co pilots can give out what editing software they are using. Thank you.
2021-10-10
Montfrooij
Flight distance : 2560453 ft
Was this a raw image?
2021-10-11
Katedrone
Montfrooij Posted at 10-11 06:13
Yes it’s raw
2021-10-11
Katedrone
DJI Stephen Posted at 10-10 21:25
I have never crashed my drone but I have had a few rougher landings.
2021-10-11
Montfrooij
Are you on the latest firmware?
I remember a bug that was just like this.
2021-10-11
DJI Stephen
Katedrone Posted at 10-11 07:09
Hi there Katedrone. Thank you for the reply and for these information that you have given. Can you please try to check if the firmware of your DJI Mini 2 is on its latest one? If still the issue persist, I would recommend for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this matter. We will do there best to help you and give out the best resolution for the said issue. Again, I am sorry and thank you. Thank you.
2021-10-12
Labroides
Flight distance : 9991457 ft
Igorka Posted at 10-12 18:57
The lines occur because of the position of the drone. You can make those lines invisible with photoshop. I cant remember how to do it. But it is possible!
The problem in the sky has nothing to do with the position of the drone.
Where did you get that idea from?
2021-10-12
Labroides
Igorka Posted at 10-12 20:14
The way the drone is facing will affect the colors.
You have no idea what you are talking about.
The way the drone faces, doesn't put a vertical division through the sky like that.
2021-10-12
