DJI FPV manual mode 120 meter height limit?
4203 12 2021-10-11
FPVSlice
Flight distance : 2935351 ft
Belgium
I realise why there are height limits regarding safety and laws.
But why am i able to fly to 500 meter in sport mode, but i can't go above 120 meters in manual mode because it kicks me out of manual mode.
It doesn't make sense to me, because in sport mode the chances of hitting a manned aerial vehicle is as high as doing it in manual.
What is the purpose and can i disable it? In the future i want to dive mountains and cliffs that wil be a lot higher than 120 meters....
2021-10-11
Max90payneFPV
Flight distance : 2832844 ft
Hello !!
I fly with the DJI FPV from Day One and immediately in manual mode !!
I fly only in the mountains where for obvious reasons following a slope you immediately exceed 120m in height ..... but not from the ground because I am always close ...
I have suffered several times the block at the 500m limit (which I have now removed) but never the 120m one
Could you be flying in an area that the DJI system deems restricted?
Have you removed the distance limit from the menu?
2021-10-11
FPVSlice
Belgium
Max90payneFPV Posted at 10-11 07:38
Hello !!
I disabled the distance limit completely but i can't remove the height limit which is 500 meters max.
But this isn't my issue. I get thrown out of manual mode when i exceed 120 meters. How can i resolve this?
Even when i fly in 'recommended' zones i get thrown out of manual when i exceed 120 meters. This doesn't make sense in my opinion.
2021-10-11
Max90payneFPV
Hello !!!
This 120m thing and back from manual to normal mode only happened to me when I had a loss of signal ...
Have you changed the area you usually fly from?
Do you seem to have some signal problem?
2021-10-11
FPVSlice
Belgium
Max90payneFPV Posted at 10-11 08:19
Hello !!!
Never noticed a signal loss, i have it in every zone. It's hard capped at 120 meter for some reason.
I have flown to 500 meters in sport mode at the same area without any issue.
2021-10-11
Max90payneFPV
FPVSlice Posted at 10-11 12:45
Hello !!
Really strange this thing !!
I would try a factory reset and a re-pairing of the whole system ....
Otherwise you have to contact DJI support !!!!
2021-10-11
Whoreable
Flight distance : 1775299 ft
download and install nfz altitude from drone-hacks
2021-10-11
FPVSlice
Belgium
Whoreable Posted at 10-11 20:56
Perhaps i'll need that! Thanks.
2021-10-11
Max90payneFPV
FPVSlice Posted at 10-11 22:42
Hello !!!
I honestly don't think that's the problem ..... I'm reading here on the forum that many have the same problem as you ....
Have you updated to the latest firmware?
If so the drone-hack system on your DJI FPV will unfortunately not work ....
2021-10-11
FPVSlice
Belgium
Max90payneFPV Posted at 10-11 23:02
Hello !!!
I do indeed have the latest firmware.
I'd like to know what causes this issue though. I would be surprised if there isn't an official solution or known bug for this???
2021-10-12
Max90payneFPV
Hello !!
Having the latest firmware you cannot, at the moment, apply the Drone-Hack system unfortunately ...
Are you flying in CE or FCC mode?
Honestly I don't know what this problem could be due to in manual mode only ...
I repeat to you I have always and only flown from the first day in manual mode and I have never had any problems.
I fly into FCC and don't have the latest update ...
2021-10-12
FPVSlice
Belgium
Max90payneFPV Posted at 10-12 04:40
Hello !!
I fly in FCC mode most of the time.
2021-10-12
Max90payneFPV
So really weird
2021-10-12
