I got the dev kit that the examples were built on the STM3240G-EVAL evaluation board .
Payload -- STM3240G-EVAL evaluation board
Skyport -- V1.3 -- Current
PSK Version -- PSDK_V2.2.1-build.315
Went through the instructions was able to connect and bind using a linux machine.
When I use the eval board --- Connections made -- Tx,Rx,GND,HighPower,PPS. Baudrate -- 921600 (Skyport V1.3) -- Triple checked the connections
I get the generic error :
[942.912][module_command]-[Error]-[PsdkCommand_SendASyncHandle:866]Command async send error 0
[942.913][module_command]-[Error]-[PsdkCommand_SendSync:338]sendSync callback timeout
[942.913][module_core]-[Error]-[PsdkCore_WaitAdapterConnection:238]Can't connect to Skyport V2 or X-Port. Probably because PSDK Adapter not power on, PSDK Adapter not finish init or UART connect error. Please check PSDK Adapter connection, UART configuration and UART connection
{Linux setup worked with similar connections }
I see that receive values are stored correctly after looking at the ring buffer in KeiluVision.
Is there some other check happening in the .lib library , did I miss something?
