Selecting codec H.264 or H265and frame rate
719 2 2021-10-11
keir
I wish to set a frame rate of 48 frames a second and set the codec.
I find that the menu on the right side panel when set to the video setting only displays the codecs and possible frame rates if the DJI controller is powered up with the Mavic 2 Enterprise Dual drone turned off. It attempting to select a codec or frame rate in this state has no effect. Nothing get selected.
If I turn the Mavic on the controller returns to the splash screen. Returning to the menu (on the right side panel) there is no selection for a codec available . In the selection for "video size" where you can normally select a frame rate the only choice is 30fps.
I have this morning updated the firmware and the problem persists.
2021-10-11
Montfrooij
Flight distance : 2560453 ft
Hi!
You might be better off posting your question in the 'products' section of this forum.
That is way more active.
Just create a new thread here : https://forum.dji.com/forum-129-1.html and select the right category / subcategory.
2021-10-11
DAFlys
You need to have the drone and controller on and paired to make a change to most of the settings.
2021-10-11
