Size error
379 3 2021-10-12
djiuser_klCBlZX441Bk
Flight distance : 38802 ft
Belgium
good afternoon i have a mavic pro platinum for some time now it fell and i have calibrate the sensors and it gives me error size already tried from 10 to 27 and does nothing I need help.  thanks
with my regards
 Carlos Filipe Fernandes
2021-10-12
DAFlys
Hi! You might be better off posting your question in the ‘products’ section of this forum.  That is way more active.    -   https://forum.dji.com/forum-129-1.html
2021-10-12
DJI Stephen
Hello there Carlos Filipe Fernandes. I am sorry for the trouble this has caused and thank you for reaching out. You may give a try to change the resolution of your screen for your reference you may take a look at this information. It is recommended to use a monitor with a size of 14 inches or more, and a curved screen is not supposed to be used. Set the display resolution to the recommended value (usually 14 inches for 1366*768 or 1440*900; 17 inches for 1366*768 or 1280*720; 19 inches for 1366*768 or 1440*900; 22 inches for 1680) *1050 or 1920*1080; 24 inches for 1920*1080 or 1920*1200). If the issue still persist and since the said DJI drone fell before. I would recommend for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this matter. We will do there best to help you and give out the best resolution for the said issue. Again, I am sorry and thank you.
2021-10-12
Belgium
thank you today i will try
2021-10-12
