New Version of 1.4.12 (1410) Does it fix the Compass?
1202 19 2021-10-12
videoeditman
Flight distance : 6713271 ft
DJI has a NEW, new version if you click their download on Fly App it will be (1410) does this fix any issues with the original 1.4.12 (1386) ???? DJI Android Download 1.4.12 (version 1410)
2021-10-12
DAFlys
Oops - Duplicate post?
2021-10-12
Mobilehomer
Flight distance : 18135846 ft
Just came in from trying it out. Everything is as it should be. The compass is correct. The front LED control is back. The streaming option is there. Distance is a little better than before. ZERO problems. I had to sign in, then set unit measurement. The flight records also show up under "Profile" immediately, they were taking a few minutes.
Now, DJI - LEAVE IT ALONE!!!!
2021-10-12
Andre vd Weide
Flight distance : 1503937 ft
yes everything looks fixt
2021-10-12
videoeditman
DAFlys Posted at 10-12 10:19
DAFlys, I posted in Mini 2 & Air 2s forums as both are affected.
2021-10-12
DAFlys
videoeditman Posted at 10-12 11:50
Ok.  But if you just click products it shows both.
2021-10-12
SnitserNL
Flight distance : 2372014 ft
Mobilehomer Posted at 10-12 10:25
As far as I can see the front LED color control issue is not yet fixed. I just checked this. Trying to change the color in the app does nothing,
2021-10-12
videoeditman
DAFlys Posted at 10-12 11:52
DAFlys, that may be.  but when I am looking specifically in Air 2s forum I keep seeing mini 2 posts. For me not a big issue but it can be confusing to some and just add to forum posts that aren't relevant to the specific forum.
2021-10-12
DAFlys
videoeditman Posted at 10-12 12:38
I find it best to stick to the top level  - works / products / social etc.
2021-10-12
ManiekWwa
Flight distance : 280026 ft
Poland
SnitserNL Posted at 10-12 12:23
I have the same problem. First I made an upgrade, second clear new instalation and still not working.
2021-10-12
djiuser_u2K7STzScjkU
Seems that all works for now with a Samsung Galaxy A71. That would be a dream. Will tell you tomorrow if it works outside.
2021-10-12
Mobilehomer
I spoke too soon. The front LED now defaults to "disabled" and slowly flashes. I just tried a few things. And the LED is has no control.  Everything else is good.
2021-10-12
Marsupilami
Flight distance : 587615 ft
same here - homepoint error is fixed (yeah...) and front-led still not able to change
2021-10-12
DJI Stephen
Hello there videoeditman. Good day and thank you for sharing this link and these information with us about the new DJI Fly application update. Have a safe and a happy flying always.
2021-10-12
Montfrooij
Flight distance : 2560453 ft
Thanks for the tip!
2021-10-12
ManiekWwa
Poland
DJI Stephen Posted at 10-12 20:06
What about LED problem?
2021-10-12
DowntownRDB
Flight distance : 1722 ft
Just came in from trying it out. Everything is as it should be. The compass is correct. The front LED control is back. The streaming option is there. Distance is a little better than before. ZERO problems. I had to sign in, then set unit measurement. The flight records also show up under "rofile" immediately, they were taking a few minutes.
    But still need to fix LED issue.
2021-10-13
Gif2D
Flight distance : 528478 ft
Romania
Do as you all wish, but I will not update as the LED is my last failure concern.
2021-10-13
djiuser_FV58ijBP4THe
Flight distance : 117418 ft
My front led still just flashing even after changing settings and colors. It stays white and only comes and goes.
2021-10-14
