CyD0n1a
Flight distance : 979757 ft
Hi, I got an Air 2s on Saturday and on my 2nd flight this week appear to have a potential issue which is concerning me somewhat.
When trying to record, I got a black screen with a triangle coming out from the left hand side of the screen. When I tried to shoot a photo, the picture area was upside down. This wasnt the phone orientation, just the actual picture area, everything else was the right way up. This seemed to happen after I tried to use the Mastershot functionality as I recall.
I landed the drone and checked it all, changed battery and it seemed fine, but this is causing me worry as to why this happened. Perhaps this was a result of ending the Mastershot function before it reached a conclusion and not ending the functionality properly? Maybe zoomed in too far with the gimble pointing downwards or similar… Any ideas or experience with something similar? Also, when you centre the gimble, is it normal that it points downwards to minus 90 degrees. I thought it would centre horizontally to the front?
See shot of triangle lines I managed to capture when trying to record, looked slightly different actually on screen, but gives you an idea…. Is it possible the gimble was turned in on itself, although not sure why this would be, had no collisions etc…. Completely puzzled by this.
Thanks in advance!
