Size error calibrate
551 1 2021-10-12
djiuser_klCBlZX441Bk
Flight distance : 38802 ft
Belgium
I have a drone dji mavic pro platinum I can't calibrate it says size error calibrate already tried several numbers 10 to 27 can someone help me
2021-10-12
DJI Stephen
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. You may give a try to change the resolution of your screen for your reference you may take a look at this information. It is recommended to use a monitor with a size of 14 inches or more, and a curved screen is not supposed to be used. Set the display resolution to the recommended value (usually 14 inches for 1366*768 or 1440*900; 17 inches for 1366*768 or 1280*720; 19 inches for 1366*768 or 1440*900; 22 inches for 1680) *1050 or 1920*1080; 24 inches for 1920*1080 or 1920*1200). Thank you.
2021-10-12
