HGDC84
Finland
The Mimo app has a setting for two different control modes. The setting is called "Gimbal Easy Control" and can be found from the Mimo app's camera view. On the left, tap the three dots on lower left corner, then tap on the camera icon - there you find the slider switch for the function. Having this on only gives you one joystick that moves in all directions, while having it off gives you two joysticks - one for tilt and another for pan axis. While that makes diagonal movements harder, it enables you to tilt or pan in a completely straight line without movements into the unintended directions.
Also, the controls on the display are analogue (though they are somewhat hard to operate without tactile feedback) - move the joystick only a little and the speed is slower, while moving it more makes the speed faster.
Besides, I do remember seeing some kind of panning option in the Story mode menu, though it seems like it's duration can't be adjusted. Feel free to correct me if I'm wrong. |
