UKMoose
Flight distance : 3657552 ft
Labroides Posted at 10-13 22:14
I took a look at a property I'm going to be mapping earlier today and when I got out there I realized I had no phone signal, so there's going to be no GPS or map to work with on-site.
Why no GPS?
The GPS signal comes from a constellation of satellites orbiting in space ... not from a cell phone tower.
Hi bud, I use litchi occasionally with no problems, however if I just go and load litchi in the field there is no map, however if I load litchi at home with WiFi and then turn off and go to the field and load again the map is there. No expert here but I guess its still in the cache, also I've found a way point mission saved at home also shows the map when I get to the field.
Now that's just what I've found with my very limited experience.
There'll be good advice from more experienced members I'm sure. |
