Create date wrong but only on Mavic 2
819 6 2021-10-14
GRCambridge
I have discovered that the create date on all images taken with my  Mavic Pro 2 for the past 6 months are all the same date of September 14th  2017,the time is the correct time but not the date.
Eg
Date/Time Original:
2021-10-14 16:14:08 EDT
Create Date:
2017-09-14 16:14:08 EDT
This is using the smart controller and have I done a firmware update today and still have the same problem.
However if I use the same smart controller with a Mini 2 there is not a problem,all is correct.
Any ideas how to solve this?
Thanks.
2021-10-14
Montfrooij
Flight distance : 2560453 ft
Hi!
You might be better off posting your question in the 'products' section of this forum.
That is way more active.
Just create a new thread here : https://forum.dji.com/forum-129-1.html and select the right category / subcategory.
2021-10-14
DAFlys
Have you tried reseting the controller to factory defaults and starting again?
2021-10-14
GRCambridge
Montfrooij Posted at 10-14 12:56
Hi!
Thanks,first post so was not exactly sure which the best one was!
2021-10-15
GRCambridge
DAFlys Posted at 10-14 23:42
No,I will give that a go tonight and let you know if it works.
2021-10-15
Montfrooij
GRCambridge Posted at 10-15 06:32
No problem at all!
2021-10-15
GRCambridge
GRCambridge Posted at 10-15 06:34
Hi,Just done the factory reset on controller and no change, still says 2017.
2021-10-17
