Phase One's Capture One is what I use. There are no specific profiles for the Inspire DNG but you can adjust it well in C1. ACDSee Ultimate 8 also works with them. My preference is DXO but it does not support the files. I added it as a suggested module but I have no idea if they will ever support it.
I just tried DJIs DNG cleaner ... and after running it through that it´s still a DNG file but my iMac can actually handle the files and import them to the image library thingy ...
w1der Posted at 2015-7-31 20:15
I just tried DJIs DNG cleaner ... and after running it through that it´s still a DNG file but my iM ...
w1der
Yep it works.
What is weird is that the original file that could not be read before the conversion can now be read after the conversion. So creating the converted file is just extra.
I can work with this now. Able to open in Preview and Photoshop.
Adobe anything should open it. Adobe invented the DNG standard as a RAW file format for any camera manufacturer to use. So unless your copy of Photoshop is very old, and assuming you keep it up to date, it should open DNG files just fine.
Also, the Mac OS can natively open DNG files (like in the Preview app) if it's a fairly recent version.
Great ... and you confirmed that it also works in Photoshop ... thats what I was hoping to hear as I am probably getting a photo editor installed next ...
Lightroom CC and Photoshop CC 2015 open the native files just fine, but...
The DJI converter also removes the dead pixels in the native DNG files so it's worth using even if whatever software you're using can actually open them as-is.
