DJI Ronin 4D | The Future Is Rolling
12Next >
38240 65 2021-10-20
DJI Panda
Flight distance : 405039 ft
DJI, the global leader in civilian drones and creative camera technology, today launches a comprehensive cinematography system that heralds the next generation of film production. DJI Ronin 4D combines the all-new full-frame Zenmuse X9 gimbal camera, a 4-axis stabilization system, a LiDAR focusing system, and an unrivaled video transmission and control system in a single unit. Designed and built to the exacting standards of professional filmmakers, DJI Ronin 4D makes high-end productions more efficient, makes spectacular camera moves possible in the most convenient way, and enables creative professionals to tell their stories with an entirely new visual language.
“DJI empowers creators with accessible and intuitive devices to capture and share the world exactly how they see it,” said Paul Pan, DJI Senior Product Line Manager. “With DJI Ronin 4D, we use the power of technology to make cinema-standard production more affordable, cinema cameras more flexible, and cinematic imaging available to a boundless array of filmmakers. DJI Ronin 4D draws on our expertise in both aerial and ground-based cinematic innovations to enable the next generation of professional content creators to amaze and inspire us.”
The Most Powerful Cinematic Imaging System DJI Has Ever Created
Excellent filmmaking begins with the perfect shot, which is why DJI developed its most powerful cinematic imaging platform to date. A flagship proprietary chipset fuels an intelligent image processing system, CineCore 3.0, which delivers an internal 8K RAW codec with precise color reproduction, advanced assistive functions with a high-performance AI engine, and multi-link monitoring and control with low-latency image processing.
Complementing the imaging system is a brand-new, full-frame Zenmuse X9 gimbal camera – available in 8K and 6K versions – that allows cinematographers to capture footage in full cinematic quality. In addition to the commonly used H.264 codec, both X9-8K and X9-6K can internally record Apple ProRes and ProRes RAW, leaving more latitude for editing in post. Zenmuse X9-6K supports up to 6K/60fps and 4K/120fps, and Zenmuse X9-8K up to 8K/75fps, giving creators multiple options for capturing cinema-quality footage.
To create gripping, atmospheric shots, the dual-native EI of 800/5,000 and over 14 stops of dynamic range help capture scenes with rich color grades, regardless of shooting scenario. Even in complicated lighting situations, DJI Ronin 4D’s proprietary DJI Cinema Color System (DCCS) delivers natural skin tones and enables effortless tonal consistency across a project when using different cinema cameras. The camera’s built-in nine-stop physical ND filters make it easy to adjust to drastically changing lighting conditions, especially when outside on location.
In addition, X9 is equipped with an interchangeable lens mount design allowing connection to DJI’s proprietary DL mount, Leica M mount, and other mounts with short-flange focal distances. This provides cinematographers the opportunity to use ultra-large aperture lenses, anamorphic lenses, and vintage manual lenses, creating their desired style.
The Industry’s First Active-Vertical 4-Axis Stabilization System
DJI Ronin 4D has been designed with an innovative industry-first active Z-axis to eliminate vertical camera shake effectively. This technology allows the operator to shoot while walking, running, or moving around dynamically, with no need to practice pacing or rely on external equipment. Videos taken in complex spaces like stairways or uneven ground are smooth without any trace of the operator’s footsteps. DJI Ronin 4D even captures wide sliding shots easily, without the need for a dolly.
Building on DJI’s years of leadership in aerial and handheld stabilization, DJI Ronin 4D achieves this unprecedented fluidity with an advanced new algorithm that processes inputs from a set of downward ToF sensors, forward and downward dual-visual sensors, built-in IMU, and barometer. Even with the additional Z-axis, DJI Ronin 4D is lighter and smaller than most cinema cameras mounted on a professional three-axis stabilizer, reducing the size and complexity of a professional camera setup into an ideal form that never existed before.
ActiveTrack Pro applies more distinctive DJI technology to get complex, advanced tracking shots easily and efficiently. Based on DJI’s existing ActiveTrack system, the Pro version uses DJI Ronin 4D’s latest artificial intelligence to track subjects from longer distances while adjusting composition to maintain optimal framing.
LiDAR Transforms Professional Focusing Experience
A newly designed LiDAR Range Finder continuously generates precise laser measurements to revolutionize filmmaking with a sharper, faster, and more reliable focusing experience. It simultaneously casts over 43,200 ranging points reaching as far as 10 meters, locating subjects quickly and accurately, even in low-light environments. Because LiDAR measures the distance to the subject without relying on surface textures or hunting for edges, it obtains a faster focus speed without compromising image quality in any way.
DJI Ronin 4D offers three focusing modes to suit the needs of every creator: manual focus, autofocus, and DJI’s unique Automated Manual Focus (AMF). In manual focus, DJI Ronin 4D provides LiDAR Waveform, an assistive tool that allows cinematographers to locate focus points and pull focus with extreme precision. Autofocus keeps a sharp focus on the subject in more dynamic and unpredictable situations like documentary filmmaking. Automated Manual Focus combines the best of both modes to automatically rotate the focus wheel while following the focus point, allowing the operator to intervene manually at any time for an intuitive experience.
Ultra-Low Latency, Long-Range, and Anti-Interference Transmission
Using DJI’s all-new O3 Pro transmission technology, the 4D Video Transmitter outputs a 1080p/60fps feed to remote monitors with a transmission range of up to nearly 20,000 feet. It also includes AES 256-bit encryption that protects the video feed and industry-leading end-to-end low latency for a smooth, real-time monitoring experience as operators move freely about the set.
In addition to 2.4GHz and 5.8GHz, O3 Pro also supports the DFS frequency band, significantly improving stability and anti-interference performance, even in crowded signal environments and locations that feature complex architectural structures. This system also enables multiple receivers with one transmitter and allows users to switch feeds quickly between multiple Ronin 4Ds.
The additional High-Bright Remote Monitor integrates a wireless video receiver into a 1,500-nit, 7-inch monitor. The built-in gyro sensor also turns the monitor into a motion controller for movement-based camera control. It can also connect to the Ronin 4D Hand Grips, DJI Master Wheels, DJI Force Pro, or the new DJI Three-Channel Follow Focus to modernize coordinated shoots. When several remote monitors are used in conjunction, each device can play back material separately with independent LUT, loaded without interfering with other monitors. The monitor’s built-in microSD card slot supports up to 1080p/60fps proxy footage recording.
Storage, Sound Recording, and Battery Life
To meet the needs of a wide range of users, DJI Ronin 4D offers three storage methods. USB SSD provides 4K projects with a cost-effective solution. The CFexpress Type-B card offers compatibility and stability. DJI’s proprietary PROSSD 1TB delivers the best performance and highest stability for internal recording at maximum resolution and frame rate.
For sound recording, DJI Ronin 4D has built-in microphones to support 2-channel 24-bit audio. It also has two 3.5mm jacks on the body and two XLR ports on the Expansion Plate for additional input and output options.
Like Ronin 2 and Inspire 2, DJI Ronin 4D uses the TB50 Intelligent Battery, which offers up to 2.5 hours of shooting time. Even in extreme weather conditions, the TB50 battery is still reliable with the help of auto-heating technology.
Co-Developed with Industry Leaders
DJI Ronin 4D comes as the solution that cinematographers all over the world have been looking for. Leading cinematography professionals have been testing prototype after prototype, giving constant feedback, and working with DJI every step of the way until Ronin 4D was complete. But the collaboration doesn’t end there. Starting today, DJI is pleased to announce that eight of the industry’s leading and award-winning DPs will work directly with DJI and Ronin 4D for their upcoming works. These include: Rodney Charters, ASC, CNSC, NZCS; Takuro Ishizaka, JSC; Rachel Morrison, ASC; XiaoShi Zhao, CNSC; and Academy Award winners for Best Cinematography: Erik Messerschmidt, ASC; Claudio Miranda, ASC; and Peter Pau, HKSC.
Pricing and Availability
DJI Ronin 4D is available in 8K and 6K combos. The 6K version features the Main Body, a Zenmuse X9-6K Gimbal Camera, LiDAR Range Finder, High-Bright Main Monitor, Hand Grips, Top Handle, TB50 Intelligent Battery, and Carrying Case; it is priced at $7,199 and will be available from store.dji.com and in other channels starting in December. The 8K version features a more powerful Zenmuse X9-8K Gimbal Camera and a PROSSD 1TB; it is priced at $11,499 and will be available from store.dji.com and other channels at a later date. To utilize Ronin 4D to its full potential, the 4D Video Transmitter, High-Bright Remote Monitor, and DJI PROSSD 1TB are available separately.
DJI Ronin 4D comes with a 2-year International Warranty for quick service at any authorized service center worldwide. For extra assurance, DJI Care Pro offers two years of comprehensive services, including technical assistance, unlimited free repairs within the coverage limit, and two maintenance services by DJI technical experts.
For more information, please visit: www.dji.com/ronin-4d
2021-10-20
Montfrooij
Flight distance : 2560453 ft
Very impressive!
2021-10-20
DAFlys
Wow,   its a really impressive camera.
2021-10-20
Visual Air
Flight distance : 2710115 ft
Super Impressive. Really a tool for the most pro film makers.
2021-10-20
JetSam
Flight distance : 3462946 ft
Amazing !!
2021-10-20
scubaAnn
Flight distance : 4425230 ft
That thing looks like a beast!
2021-10-20
CineAir Chicago
Hikes! Really? How can anyone get excited about anything knowing their history, just what I want, another DJI product that costs an arm and a leg, only works like it should 95% of the time, has some epic fail bugs in it that never get fixed by a software update or is ignored by DJI, and then the whole system or parts of it become obsolete after a short time, Or DJI just abandons them and moves on, ie Crystal Sky Monitor, Cendence Paddle Antenna controller, Ronin RS2 wobble issue and and and. Why the heck would I invest in this when I can go with something tried and true like an industry-standard, Sony or Arri, or anyone other than DJI.
2021-10-20
Eric Bartolo
Flight distance : 21877946 ft
Malta
DJI breaking the boundaries and on top of their innovation gain, well done - super excited for this journey DJI is venturing into
2021-10-20
Skyris
Flight distance : 333799 ft
wondering what drone this will mount on to
2021-10-20
johansenfoto
Flight distance : 1173379 ft
Norway
If I only could win in Lottery
2021-10-20
DJI Stephen
Hello there Montfrooij. Thank you for the reply and for the positive feedback for the DJI Ronin 4D. If you have any inquiries with the new DJI Ronin 4D. Please feel free to post it here at DJI Forum. We are all here to assist you.
2021-10-20
Montfrooij
DJI Stephen Posted at 10-20 19:26
Thanks a lot, I will
2021-10-20
ABeardedItalian
Flight distance : 1063107 ft
CineAir Chicago Posted at 10-20 09:47
Whole heartedly this ^^^
So much talk about who they partnered with, how big it can shoot, no talk about sensor, no talk about lens, great a $12k camera with it's own proprietary lens's just what every cinematographer wants...
Not to mention this camera is gimbal on gimbal, should have the smoothest video right?
@3:02 Yikes I can still see the foot step bounce.... Even gopro can smooth video out better then this.
A better question to ask, will this camera be supported by industry? Netflix has strict requirments with what you can film with on it's platform: Netflix:  Cameras and Image Capture
2021-10-21
DJI Stephen
Hi there Montfrooij. You are very much welcome and thank you for the reply. Have a safe and a happy filming always. .
2021-10-21
chesterbenn
would like to see details on the horizon drift issue, how solid it is when locking the gimbal off to put on longer lenses, the support of dng raw or black magic raw for non apple users, as well as if the very expensive wireless monitor you buy is only good for this camera and nothing else. also for recording options is the limited recording settings with a consumer nvme ssd just a recommendation or a hard software block, for example the Fx6 suggests you use their faster (and expensive) cfexpress type A on certain modes yet the camera will still let you run it if selected with only an sd card which saves a lot of money.
2021-10-21
M2Wair
Flight distance : 1192231 ft
It's seriously impressive, but for now I'll stick with my Sony and Canon set ups until such a time as it's proven. I was tempted lol once bitten twice shy.
2021-10-24
ENAGUAS
Mexico
Does anyone know if the zenmuse x9 will be compatible with Inspire 2?
2021-10-25
djiuser_uDXOe9broeOy
Pakistan
Such a great and awesome camera. I like it the most. It has interesting features for capturing moments.
2021-11-2
Andy Galvez
Sweden
I just order the 8k version, is there any release date from DJI yet for the 8k?
//Andy
2021-11-9
sheridan.pennell
Probably been asked but anyone know of shipping date I'm in UK and was told December but I don't think that will happen?
2021-11-29
fans3b769c57
Hey DJI its December
2021-12-3
djiuser_TGTbJwn719oO
Sri Lanka
Dji is most biggest drone manufacture in the world
2021-12-4
Sri Lanka
Andy Galvez Posted at 11-9 00:54
//Andy
2021-12-4
Sri Lanka
fans3b769c57 Posted at 12-3 09:20
2021-12-4
Sri Lanka
djiuser_uDXOe9broeOy Posted at 11-2 10:57
2021-12-4
fans55abbfdb
sheridan.pennell Posted at 11-29 03:45
so no one knows???
2021-12-7
rone4
Flight distance : 830564 ft
Did you find out about the shipping date?
2021-12-8
fans55abbfdb
rone4 Posted at 12-8 22:57
No no-one seems to know the answer doubt it will be December
2021-12-11
rone4
Bit disappointed with that. Sold my Komodo and was looking forward to Christmas blast with it.
Got the DL lenses though. Wish there was an 85mm.
2021-12-12
LeroyWolf
Flight distance : 84288 ft
When release.
I'm refreshing the site every day for an update. Some sort of communication would be nice.
2021-12-13
Jose Miguel Puech
Flight distance : 2314780 ft
impresionante producto!
2021-12-14
fans55abbfdb
LeroyWolf Posted at 12-13 05:33
When release.
Exactly! why is no one mentioning it?
2021-12-16
Dong ZeYuan
Flight distance : 57060 ft
Thanks for sharing.
2021-12-21
djiuser_Ii6cRcDZ0XrY
Jordan
#تجمع_هواة_الدرونز_dji_الاردن
2021-12-29
Dong ZeYuan
Thanks for sharing
2021-12-30
djiuser_7h53HvVw9sVT
Flight distance : 596378 ft
South Africa
Wow this is a great camera combination, I love it
2022-1-13
ExplorickOne
Very impressive video equipment.
2022-1-14
thirald
Flight distance : 131713 ft
Super Impressive
2022-2-5
andreadamibrazi
Brazil
wow !!!!!!!
2022-2-8
djiuser_hco5ObTmZQDy
Turkey
Looks awesome but how much it cost?
2022-2-9
12Next >
