DNG Files Have center hot spot
614 4 2021-10-20
tallsean
Flight distance : 338635 ft
Why do all my Mavic air 2 DNG files have a center hot spot and is it possible to remove it? I use the latest Capture one Pro version to edit photos.
2021-10-20
DJI Stephen
Hello there tallsean. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please post some sample photos showing the said issue for us to see and can assist you further? Thank you.
2021-10-20
tallsean
There's a hot spot / halo in the middle of all my DNG files
2021-10-21
dreamergr
Flight distance : 1047251 ft
Greece
Greetings, Im no expert but i only see it on the 2nd picture.
Maybe bad ND filter? Or even ND from DJI? Try to look at a solid color so you can see clearly if there is or not. Also clear the lens with Glass cleaning cloth?
Just some ideas! Hope you find a solution!
2021-10-21
tallsean
There's a halo in the middle of all the photos. The sky should be equally blue across the horizon.
The lens is clear and I didn't use any ND filters; maybe I should have.
Thanks for trying.
2021-10-22
