1.4.12 (1425)
699 8 2021-10-22
otomek77
Flight distance : 6819160 ft
Poland
Yes...DJI just released new version of DJI Fly (1.4.12 - 1425) and we still have the same bugs like in previous. Still not working manage of front led (DJI mini 2), battery status in menu not contain date of production and still you can not back to default settings when you use adavnced settings of gimbal :-(. In my country wind is blowing very strong and I can not check this app if about flying impressions. Dear DJI why you release next version with so many bugs?
Would be perfect if DJI team could change the colour of bottom right "MM" indicator for PRO mode as now very often I can not see result of indication. This indicator should turn red when the image is underexposed and overexposed, for example, and turn green when the level is between -0.3 and + 0.3.
Regards
Tomasz
screenshot
screenshot
2021-10-22
Sailor2021
Flight distance : 25069 ft
Hello, are you installing an older version again?
2021-10-22
otomek77
Poland
Sailor2021 Posted at 10-22 08:40
Firstly I will check flight experience when weather get better (Sunday) and then I will decide if back to 1.4.8. The current bugs are annoying, but they are not crucial when it comes to flying.
2021-10-22
Pappy3
Flight distance : 2820469 ft
Better check again, there's another build that has been released -1430 (DJI-v1.4.12-211022-1430-48641-official-sec.apk). This is build #3 for this release.  The past two releases (not builds) have been buggy, so I'm sitting this one out.
2021-10-22
alexair
Flight distance : 1496644 ft
Pappy3 Posted at 10-22 20:08
where is it ,this last 1430  version?
(  ignore my question,   I found here:  https://www.dji.com/downloads/djiapp/dji-fly
thanks
Alex
2021-10-22
DAFlys
I think this is android only.
2021-10-23
Nelsonlee
Flight distance : 2779203 ft
Malaysia
DJI Fly up to date now is (1.4.12 - 1430)
2021-10-23
otomek77
Poland
Nelsonlee Posted at 10-23 00:41
I just instaled....still the same bugs...lack of battery production date, no working front led manager, problem with reset advanced settings of gimbal to default.
2021-10-23
djiuser_WC9wSnaJWhBt
Flight distance : 948383 ft
I am still not getting photos cached on my Android device with the SD card in the mini 2 on the latest Android build.
2021-10-23
