Brand new Mini 2 showing Connection ESC error Code: 30085
11855 18 2021-10-30
dougscortegagna
Flight distance : 47365 ft
Brazil
Hi folks,
I live in Brazil and purchased a DJI Mini 2 Fly More Combo from the official DJI Ali Store at AliExpress and it got delivered yesterday  (29 October 2021).  I recorded the unboxing and noticed that the gimbal cover wasn't well fixed.  Besides that, everything looked normal. Turned on the drone and got ESC Error Code: 30085 with a static red light
I've updated all firmwares and still having this problem. If i do IMU Callibration it works, but when i turn off and on the problem returns. Tried with every battery also. I've never crashed it, just made a test flyght when it turns on, but i'm scared that this problem could happen in the air.
I looked online and found people with same error, like this (https://forum.dji.com/thread-238209-1-1.html) and DJI gave them  a new drone.
What should i do? I live in Brazil and DJI Brazil won`t give me support because I didn't buy my Mini 2 in Brazil.
Cheers
2021-10-30
DJI Susan
Hi there, I am sorry for the issue you experienced. For the ESC error, please try to remove the SD card and restart the drone, ensure that the firmware has been updated to the latest version.
If the error persists, you may need to send the drone in for service. You may try to contact the reseller to see if they can help you out. I noticed that you had contacted our support via email, I will ask the team to follow up on your case as soon as possible.
2021-10-31
dougscortegagna
Brazil
DJI Susan Posted at 10-31 01:16
Hi Susan,
I tried this and still have the problem. Just now i tried to turn the Drone 10 times, it turned on OK 2 times, and 8 times it gave me back the static red light with ESC Connection Error.
Removed the SD Card, formatted it, updated all the firmwares and the DJI App and the problem still persists.
When it turns on, i can fly it, but i`m scared that this is a serious problem.
2021-10-31
DJI Susan
dougscortegagna Posted at 10-31 03:37
Hi Susan,
I am sorry for the result. If the error appears frequently, you may need to send the unit back for diagnosis and service.
2021-11-1
dougscortegagna
Brazil
Updating the situation. I sent it to DJI Brasil, I was very well attended, it was a problem with the ESC board, as the Drone was not manufactured in Brazil, there was no warranty, but the cost was R$ 515.00 (they changed the  ESC board). The entire send-to-receive process took about 10 days. Now it is working 100%.
As for Aliexpress and DJI Ali Store, score 0. The seller no longer responded, nor did I negotiate a possible partial refund to pay the costs I got. Tried to contact Aliexpress, with no success either, no effort to help the buyer...
2022-1-3
djiuser_pgmF2HU3J2ep
Argentina
Hola dougscortegagna ,  tampoco SUSANA te contesto mas. una vergüenza..
tenían que cambiar  el drone , si estaba nuevo!!!
2022-1-29
Rodrigo Inacio
Brazil
My Mini 3 PRO, with DJI RC, and Fly more PLUS, after spent more than  1500 dollars, since it was unboxed, it presents ESC ERROR ... Before my  first flight it asked to update ... since this moment, it has ESC  issues. I have tried to downgrade, refresh the firmware ... the error is  istll there ... if I go sleep, at the morming the error disappear  magically... But any try to update the firmware of the drone or the  battery, the error returns and keep there for many time (I can not say  how long) and than desappear, as I have already said, MAGICALLY. SO,  AFTER ONE MONTH, I JUST FLYED FOR 55 MINUTES, BECAUSE I DO NOT TRUST IN  MY MINI 3 PRO. I am very very very sad ... and disappointed.
PS: It is not my first drone. I have a MAVIC PRO (since 2016), a Mini 2 (since this year) and now the MINI 3 PRO was my last purchase. All them are DJI, but now, my confidence is in check, because these issues related above.
2022-7-14
Shrinivas Naik
India
After the use of 8 days I am experiencing the ESC ERROR
for my DJI MINI SE.
I had purchased through XBOOM UTILITIES INDIA
and no solution found after contacting the supporting team
Plz arrange for the replacement or repair of the same
2022-9-18
Ivan Steve
djiuser_pgmF2HU3J2ep Posted at 2022-1-29 17:00
Spanish please, traductor google, hola he probado que en 7 minutos con la bateria afuera el dron nuevamente capta normal y desaparece esc error, es problema de software, prueben 7 minutos sacando la bateria, me avisan ,mi correo es ivancarbajaloficial@hotmail.com , soy de peru ,saludos
2023-3-3
ferney preciado
Flight distance : 31381 ft
Colombia
Recién acaba de arrojarme el dji mini 2 ese error después de una caída pequeña, hice todo lo que ví sobre calibrar la imu, cambiar de batería, no probé quitar SD ya que no tenía en ese momento, y cuando me había dado por perdido destape el dron usando la herramienta que viene con el y la sorpresa de que me lleve después de revisar la placa ESC, el cable o Flex que comunica la placa principal con la placa ESC, se había soltado producto de la caída, la placa ESC, es la placa que se encuentra en la parte superior y la placa principal la inferior, espero le sea útil a alguno la información antes de llevarlo a un servicio técnico, cabe destacar que el mini 2 es muy fácil de abrir y hacer cualquier reparación
1-14 10:23
DJI Gamora
ferney preciado Posted at 1-14 10:23
Hello, there. Thank you for sharing your input. For a friendly reminder, self-repair isn't in accordance with our after-sales policy and it may affect the warranty of the product. If the problem persists after the recommendations from our support, it's advisable to send the aircraft instead for repair and possible warranty coverage depending on the result and status of the aircraft. We thank you for your understanding.
1-19 00:53
djiuser_0eX1lvD9hqsK
Flight distance : 20981 ft
Hi is this coil could be the problem of esc error
3-22 14:17
DJI Paladin
Flight distance : 318 ft
djiuser_0eX1lvD9hqsK Posted at 3-22 14:17
Hello there. Thank you for reaching out. Can you confirm if you also received an ESC error on your DJI Fly app using your drone? Also, does the drone experienced a hard landing before? Please upload the screenshot of the error message here so we can check it further. We will wait for your response.
3-22 20:33
DJI Paladin Posted at 3-22 20:33
Yes i do get esc error. I received dron from auctions and probability it was in hard lending. As his gimbal was detached from his body and hanging on a signal cable. It was like crime scene
3-23 02:39
DJI Paladin
djiuser_0eX1lvD9hqsK Posted at 3-23 02:39
Hi. We do apologize if you experience trouble with your unit. Since we do not recommend DIY repair for flight safety, you may contact our team at https://www.dji.com/support to have guidance on how to send the unit to us for further diagnostics. Should you have other inquiries, please don't hesitate to reach us. We appreciate your valued support.
3-24 03:01
AldoApache
Portugal
My drone was stored for about 1 year, in a hardcase, and now I face several problems being able to use it.
1st esc error
2nd I can't update the firmware, either on the phone or on the computer. The update gets stuck at the final 34%, and then fails, several times showing different errors.
4-1 16:14
DJI Tony
AldoApache Posted at 4-1 16:14
[view_image][view_image][view_image][view_image]
Hello there. Thank you for reaching out. Have you already tried removing the SD card and then restarting the aircraft? If the issue persists after removing it, please retry updating the firmware. Thank you.
4-1 21:46
AldoApache
Portugal
DJI Tony Posted at 4-1 21:46
Yes, I literally spent the whole day trying to update in every way, over and over again, until I didn't have any batteries left with a charge. This is considering that the drone connected to the computer continues to charge itself.
How do I send the drone in for some maintenance?
4-2 04:13
DJI Tony
AldoApache Posted at 4-2 04:13
Hi. Thank you for the update. You can submit a repair request here [url]https://repair.dji.com/pt/repair/index[/url]. The warranty can be applied depending on the assessment's outcome, including your unit's warranty period. Please feel free to keep us posted if you have further concerns. Have a nice day.
4-3 01:05
