Daninho
![](https://forum44.djicdn.com/data/attachment/common/c5/common_13_usergroup_icon.png) lvl.4
Flight distance : 70203 ft
It isnt caused because of unbalanced props, they have hardly to do with it. Jello is caused because of a bad gimbal, not within the optimal specifications. I had two Phantom3 Gimbals with jello and one without it, all three tested with the same props. Now my gimbal has no jello at all even in the brightest sunshine and wind becasue the gimbal is a good copy. I had the same story with the H3-2D / H3-3D. ND Filter can mask the jello effect a bit under 1/100 shutterspeed but you will always get a not as sharp image as with a gimbal wihout jello+ND Filter. So a non jello gimbal with ND filter is sharper compared to a jello gimbal with ND filter, thats the hard lesson i learned in 2,5 years. |
