DJI Ronin 4D | Putting the 6K Raw To the Test
12Next >
1247 52 2021-11-2
DAFlys
2021-11-2
Montfrooij
Flight distance : 2560453 ft
Looks very good!
2021-11-3
DAFlys
They do look good,  but the size of the footage is insane in 6k raw from what he said.
2021-11-3
Montfrooij
DAFlys Posted at 11-3 01:39
Yup. It is.
Not funny.
You need that 8TB MBP with everything maxed out.
2021-11-3
DAFlys
Montfrooij Posted at 11-3 03:11
Yup. It is.
Not funny.
He's editing on the last gen M1 and he said it was still smooth.
2021-11-3
Montfrooij
DAFlys Posted at 11-3 04:16
That is promising.
I could not listen to the sound, so had to do it with video only.
2021-11-3
DAFlys
Montfrooij Posted at 11-3 04:30
That is promising.
Ah.  I see how you'd would midd quite a lot then.
2021-11-3
Montfrooij
DAFlys Posted at 11-3 04:35
The sounddevice was taken by the rendering of the video.
2021-11-3
DAFlys
Montfrooij Posted at 11-3 04:49
Not a problem macs suffer from.
2021-11-3
Montfrooij
DAFlys Posted at 11-3 04:54
I know.
It is a setting for some drivers, but not the one I'm using right now.
2021-11-3
DAFlys
Montfrooij Posted at 11-3 04:56
I know.
I bet you’ve got a fancy sound card in that rig.
2021-11-3
Montfrooij
DAFlys Posted at 11-3 06:49
Not ATM.
I'm using the drum machine as an interface since the real one is back for repair.
2021-11-3
DAFlys
Montfrooij Posted at 11-3 08:44
Not ATM.
Now that boggles the mind as an IT guy.
2021-11-3
Montfrooij
DAFlys Posted at 11-3 09:10
Had a bit of bad luck with my interface.
Back for the second time.
Hope they will fix it now.
2021-11-3
DAFlys
Montfrooij Posted at 11-3 11:13
Thats a PITA.
2021-11-4
Montfrooij
It is.
And I really don't like it.
2021-11-4
Montfrooij
Especially since the problem only occurs every now and then.
Clearly they failed to fix it last time.
Confidence is not really boosted by that.
2021-11-4
DAFlys
Montfrooij Posted at 11-4 01:01
Those intermittent faults can be the hardest to find.
2021-11-4
DJI Paladin
Flight distance : 318 ft
Hi, DA. Thanks for sharing this video with us. Take care always!
2021-11-4
Montfrooij
DAFlys Posted at 11-4 01:12
Exactly.
CPU temp was 'ok' I think.
<70C
2021-11-4
DAFlys
Montfrooij Posted at 11-4 11:40
Exactly.
Depends on the model but anything under a 7th gen intel doing 70c is really good if at full load.
2021-11-4
Montfrooij
DAFlys Posted at 11-4 11:51
Not sure what gen I have, but I thought it was ok (and looked it up on Google, which stated it was)
2021-11-4
DAFlys
Montfrooij Posted at 11-4 11:54
70c is a good temperature.  Temp core does tell you which cou you have so google will know the answer as you’ve done.
2021-11-4
Montfrooij
DAFlys Posted at 11-4 12:09
I could not find your link (we talk too much), so I installed HWMonitor. I will check.
2021-11-4
Montfrooij
i7 7700
2021-11-4
DAFlys
Very nice.  70c is a good temp for that.
2021-11-4
DAFlys
Montfrooij Posted at 11-4 12:13
I’ve used that too.  I prefer core temp personally. But they gets the job done.
2021-11-4
Montfrooij
DAFlys Posted at 11-4 12:23
I guess the dust has not blocked anything yet.
2021-11-4
Montfrooij
I could not find your link, so this one was the one I found next
2021-11-4
DAFlys
Montfrooij Posted at 11-4 12:24
Doesn’t sound like it.
2021-11-4
DAFlys
Here’s the link again
https://www.alcpu.com/CoreTemp/
2021-11-4
Montfrooij
DAFlys Posted at 11-4 12:45
Well.
I have to disagree.
It sounds like it is about to take off.
But that has been like that since when I got it.
2021-11-4
Montfrooij
DAFlys Posted at 11-4 12:46
Thanks. Bookmarking it now!
2021-11-4
DAFlys
Montfrooij Posted at 11-4 13:28
Well.
I have to disagree.
Noctua fans are very quiet if you want a little upgrade.
2021-11-4
DAFlys
No probs.  It’s a good little tool. And will show leaks over time too.
2021-11-4
Montfrooij
DAFlys Posted at 11-4 13:40
It's a business laptop, so I'm not doing anything to it.
2021-11-4
Montfrooij
DAFlys Posted at 11-4 13:41
Nice I will try it out.
2021-11-4
DAFlys
Montfrooij Posted at 11-4 23:49
Indeed,   best not too.
2021-11-5
DAFlys
leaks = peaks.
2021-11-5
Montfrooij
DAFlys Posted at 11-5 00:25
Who knows. One day a MBP maybe.
2021-11-5
12Next >
