mappe sul radiocomando
590 8 2021-11-4
Birbacane
Buonasera,
ho una problema probabilmente molto banale che mi sta assillando da giorni. Non riesco più a visualizzare la mappa MAPBOX sul radiocomando del mio drone MAVIC 2 ENTERPRISE. Come posso risolvere il problema?
Buona giornata
2021-11-4
DJI Wanda
Hello, there. Sorry for any inconvenience caused. Please note that we are using a translator to comprehend your issue. May we double confirm that whether the Mapbox in your DJI Pilot went black when you try to load it or it just disappeared and can not be found on DJI Pilot App?
2021-11-4
Birbacane
Hello thank you for your reply. When I open app dji pilot I can not to see map. Please see yuo attached picture.
Than you in advance for your help.
Excuseme for my english.
2021-11-5
Birbacane
DJI Wanda Posted at 11-4 19:12
2021-11-5
DJI Wanda
Birbacane Posted at 11-5 02:31
Thank you for your reply. Could you please tell us the version of the DJI Pilot App?
2021-11-5
Birbacane
DJI Wanda Posted at 11-5 22:03
Thank you for the reply. I have the version v2.3.1.5
Thank you so much
2021-11-6
DJI Gamora
Birbacane Posted at 11-6 07:03
Thank you so much
Hi, there. Here are some tips for you to get a reference. Hope the answer is helpful to you.
1. Please confirm that the offline map has been downloaded for your location;
2. Please make sure that the downloaded offline map matches the selected map source: if you are downloading a map of AMap, the map source selection must be AMap; if you are downloading Mapbox, the map source selection must be Mapbox;
3. Please make sure that when you use the offline map, the map setting display is [Standard]: The offline map download is a standard map, and the map setting must be [Standard] to display, not [Satellite].
2021-11-6
Birbacane
Thank you for your tips. They were very usefull. Now I can see the map. I have another question. Can I see also satellite map?
2021-11-7
Birbacane Posted at 11-7 07:02
Hi there, we're glad to know it works. Please note that offline maps only support the standard map, not the satellite map. If you need to use the satellite map, you need to connect the control to the network. And then set the map to 'Satellite'.
2021-11-7
