Recalibrate vision system fails on right side???
813 1 2021-11-6
rgfrancis
Flight distance : 182133 ft
So I continue to get the error to recalibrate the vision system. Luckily it will let me continue to fly because I can't get it to recalibrate. When I attempt to recalibrate using the PC DJI Assistant a couple of weird things happen.
First I get an "Attitude Error. Rotate the aircraft to the left 90 degrees" error when I start calibrating the front sensors. The forces me to rotate the drone on its side which is not how it shows on the screen or on the tutorial. Maybe this isn't a big deal but I have to continue calibrating with the drone on its side.
I am able to calibrate the front, then bottom, then back with no problems. Immediately after calibrating the back sensors, I get this screen which counts down from 10 but I have no idea what it is trying to tell me. I guess there is an image reference missing.
After I select OK I basically have to figure out that it wants to calibrate the right side by what video I see on the mini-screens on the bottom right corner of the DJI Assistant. Now two different things have happened. The first time I was able to lock on to the square corners and then follow the block around but it would always lock up on the top right box. Other times I can't even get the drone to lock on to the square corners at all.
https://www.youtube.com/watch?v=XMJwMPUXdg4
Any idea what the problem may be? Thanks in advance for any help.
2021-11-6
rgfrancis
So 42 views and 4 days and no one has anything to say. I guess the forum is not good for support.
2021-11-10
