Drone version not found
938 0 2021-11-8
djiuser_y25J4ZxR5JXi
I am trying to use an Nvidia Jetson Nano as an onboard computer to communicate with the Matrice 300 RTK using the OSDK. The computer and drone are connected using the OSDK Expansion module. I am using the dual USB cable (USB 3 Type A) to connect to the USB port on the computer.
I am getting the error
ERRORLOG/1 @ getDroneVersion, L1707: Drone version not obtained! Please do not proceed.
Possible reasons:
        Serial port connection:
                * SDK is not enabled, please check DJI Assistant2 -> SDK -> [v] Enable API Control.
                * Baudrate is not correct, please double-check from DJI Assistant2 -> SDK -> baudrate.
                * TX and RX pins are invert
[4290298.543]STATUS/1 @ functionalSetUp, L282: Shake hand with drone Fail ! Cannot get drone version. (1/20)
I have tried using all of the baud rates available in DJI Assistant 2 (changing them in both the app and the UserConfig.txt) and had no luck.
These are the current contents of my UserConfig.txt (without my actual app id and app key)
  app_id : [id]
  app_key : [key]
  device : /dev/ttyTHS1
  baudrate : 921600
  acm_port : /dev/ttyACM0
Thank you.
2021-11-8
