Any way to connect a Nikon D5300 with a DJI RSC 2?
2734 3 2021-11-9
fans1e352ab1
Greece
I've been doing some research and I couldn't find any options so far.
I know of a weird combo of adapters plus a cable to connect a D5300 with a RSC (older model) but not this one...
Any hints will be appreciated.
Thanks in advance.
E.
2021-11-9
Hi there, you can refer to the tutorial below to see if it helps. Since the said camera is not on the compatibility list, the performance is not guaranteed. Hope you can understand. https://www.dji.com/support/comp ... =rsc-2&from=nav
2021-11-9
fans1e352ab1
Greece
Thanks for response.
I know it is not compatible...  but i'm not looking for full compatibility either.
I just want a cable to allow me to press record and stop from the gimbal...
2021-11-9
djiuser_FBr7x0DsNxDB
Saudi Arabia
fans1e352ab1 Posted at 2021-11-9 03:42
May i know whats the cable way and is there any new way you found out?
4-11 05:54
