I've seem posts about the uncontrolled shaking at power up, but his is more of a slight vertical shimmy. (See Video). The shaking continues even after it flys. The camera still works, but shaky. I don't feel any resistence when moving it by hand. I don't see any obvious signs of damage. Software says gimbal stuck. Calbrating the gimbal simply sits at 0%. Firmware has been updated.
I was not the last pilot so it may have crashed, but I don't know.
Any thoughts before I look into repair? I can probably replace the gimbal but I 'm not sure it's broken or even the problem. I can dissaenble and reassemble it. It's out of warranty.
Great idea. Tried it but no luck. On that same thought I also slide some tape down the side of the vertical tilt hinges hoping I could pop something loose. No luck there, either.
When mine does this, I just gently touch the camera while it is doing it. This stops it. If this does not do it, I would open a ticket with DJI support.
Hello there Jblo. I am sorry to know that you are having this issue with the gimbal of your DJI Mini 2. Since you are having this issue I would recommend for you to contact our DJI support team at https://www.dji.com/support?site=brandsite&from=nav for further assistance. We will do there best to evaluate the said DJI drone and will give out the best resolution for this issue. Just a reminder that DJI do not recommend doing a DIY in fixing the said DJI drone to avoid further damaging the said unit. Thank you.
