skyscope
Flight distance : 4202785 ft
KerryG Posted at 11-10 12:25
Of course, most cameras do this. What was strange is that in Slow Motion, the lower the resolution, the tighter the crop. You would think this would be the other way around.
You're just lokking at a horizontal Crop when switching from Cinema 4K (DCI 4K) to 4K, and that's because of the different aspect ratios: DCI 4K is 17:9, 4K ist 16:9.
Look at the C4K at your video, you have black bars above and below, because your export is 16:9. Now take a look at the 4K example. The borders are cropped now, but there is no vertical Crop, and the clip fills the whole frame with 16:9 aspect ratio.
Alkernativly you can set up your Timeline for 17:9 Export, but then a 4K Clip will be cropped at the top and the bottom, then without horizontal crop.
So you have to opt for the lesser evil when dealing with different aspect ratios.
