Mavic 3 rear arms shaking
1358 18 2021-11-13
Jairo83
Hi all, I noticed that the rear arms of the drone shakes a lot, is this normal or should I contact assistance?
Here a small video
Thank you
2021-11-13
stupat78
Flight distance : 1204259 ft
No idea if it's a common issue or not but from an engineering standpoint that is only going to get worse over time. I'd contact support and see what they say.
2021-11-13
Flormo2002
Flight distance : 12242710 ft
More likely, the prop is out of balance. Try replacing all props or at least the rear with the extras your kit came with.
2021-11-13
Jairo83
Flormo2002 Posted at 11-13 04:45
Sorry, I forgot to mention it, but of course I tested with different propellers. I bought the fly more combo and I tested every propellers available that are 4 for each type. Same results. The problem looks more like a flex or an excessive tolerance in the articulation of the arm
Edit: after further investigation, I confirm the arm can move a cuople of millimeters (measured at the the top end of the arm).
Here the video
Has anyone else noticed this problem?
2021-11-13
fans589cba4b
Flight distance : 12780633 ft
had the same. i just replaced the propeller and it went away. the one that came attached was probably out of shape.
2021-11-13
Aeropeaks
Flight distance : 26618251 ft
Contact quickly the support, and send them our video... Stop your flights...
https://www.dji.com/support
mine his stable and have bot this trouble
2021-11-13
Jairo83
Aeropeaks Posted at 11-13 09:15
Mine flys stable too, but from a mechanical point of view, this issue could cause problems in future. What I'm trying to understand if it's working as intended or not, and if someone else noticed the same behavior.
The assistance looks offline right now in my country, I'll try to contact them Monday next week.
2021-11-13
Montfrooij
Flight distance : 2560453 ft
THat looks out of balance.
2021-11-13
Jairo83
Montfrooij Posted at 11-13 10:58
Yes, looks like that. As mentioned I tested with different propellers, but I get always the same results. If you look the first video, the front arms doesn’t shake. So I ussume that propellers are balanced, but if I switch the front propellers with the back propellers, the back arms keep shaking. Tomorrow I’ll test if the motor rotation without propellers cause shaking too, maybe is something wrong with the motors
2021-11-13
Montfrooij
Jairo83 Posted at 11-13 12:20
Hope you get it sorted out.
2021-11-13
Suren
Flight distance : 13425892 ft
New Zealand
I would get the drone replaced, not worth paying that much for the drone and having issues.
2021-11-13
hallmark007
Flight distance : 9827923 ft
Doesn’t look right contact dji support.com
2021-11-13
ZeuS-FL
Flight distance : 5782297 ft
This is probably a motor out of balance or shaft bend. I will contact support and get it replaced ASAP.
2021-11-13
Jairo83
Thank you all for your advices, I’ll do it.
2021-11-13
GaryDoug
Flight distance : 1264639 ft
I do not see the same vibrations in the rear arms of mine. But I do see the same amount of "play" in them as you do. If replacing props does not fix it, then I would start a repair case.
2021-11-13
fans24813cfd
Flight distance : 5913222 ft
I am having the same issue: https://forum.dji.com/forum.php?mod=viewthread&tid=253460
2021-11-16
fans589cba4b
fans589cba4b Posted at 11-13 09:07
NO. it's happening again. with the new props i'm still getting the shake in the rear legs.
2021-12-5
GaryDoug
fans589cba4b Posted at 12-5 20:35
I suspect that the bushing mounts in the arm joints were not installed correctly. Return it.
2021-12-5
Lewis Gaming
Having the same was quite bad at one point also if you look on the rear arms it’s rubbing against the body of the drone effectively weakening the plastic of the arm not sure if it’s the cause or it’s a cause from the shaking
4-25 14:25
