RC Pro - Connected to WiFi, no internet?
2734 11 2021-11-19
TeddyBear
Flight distance : 152044 ft
Has anyone else had issues with their RC Pro connecting to their WiFi, getting an IP, but not having any internet? I have an Asus XT8 Mesh system, and this is the most frustrated I've been with technology in years. It connects to my wifi just fine, but refuses to connect to the internet. I got it to connect to my phone's hotspot just fine, and it downloads just fine from my phone's hotspot. If I do an unsecured, open guest network, it still doesn't work. Anyone have any ideas? This is just depressing.
2021-11-19
JohnDG
Flight distance : 1097270 ft
Malaysia
Did you have an IP address in the range of the DHCP settings of your router? Or you have gat a APiPA (automatic address when not getting one from the router)?
Is the gateway on the controller set to the IP-address of Router?
Is the DNS set correctly?
In the asus router OS you can see which devices are on. You can also deprive devices of getting thru the Internet.
Btw I'm using a GT-AX11000 and a Rt-5300 in mesh, no problem connecting my Smart Controller (1st edition) to connect to the Internet.
2021-11-19
TeddyBear
JohnDG Posted at 11-19 15:47
This is a router/mesh that's been in use for quite awhile; it's got a DNS in the normal range, everything LOOKS normal, but it's acting like it's not got a DNS, even though it claims it does. It let me update the controller to the new firmware just fine earlier, but now it's just failing immediately when you try to connect to anything on the Asus setup (again, works fine tethered to my iphone), even though it claims it's connected normally. It's incredibly frustrating.
2021-11-19
TeddyBear
We finally got it to work by forcing a static ip; not really sure who is at fault here, Asus, DJI, or Google
2021-11-19
DowntownRDB
Flight distance : 1722 ft
TeddyBear Posted at 11-19 16:09
Not sure who you can blame but I'm glad you got the issue resolved.  Sometimes that kind of an issue can drive your stress levels through the roof.
2021-11-19
JohnDG
Malaysia
Networking isn't as easy as it might seem to be. A protocol that isn't supported on a device can make life quite difficult.
I noticed in the past the SC has somewhat more problems on 5GHz, and connects more easely on 2.5.
As you state a static address solved the problem, it might have been something with the DHCP server from your system.
Anyway, you got it solved  That's the main thing.
2021-11-19
TeddyBear
DowntownRDB Posted at 11-19 16:50
Oh it definitely did! Asus's router interface is abysmal, glitchy, and every tiny little change of settings requires a reboot. I wish someone could make decent home wifi hardware/software.
2021-11-20
KLRSKIR
Flight distance : 28368625 ft
I had to mess with IPv6 on my Asus router/extender to get the RC PRO to do anything. Don't be fooled, Asus makes quality hardware.
2021-11-20
TeddyBear
KLRSKIR Posted at 11-20 13:32
Our Mesh system reboots multiple times a day, not so sure about that. XD It's been, I'd say, on par with the Orbi setup we used to have (until it died).
2021-11-20
DowntownRDB
TeddyBear Posted at 11-20 13:17
    Wouldn't that be nice.
2021-11-21
Westwind77
Flight distance : 567234 ft
I am having the same issue with my Asus router. Works with my phones hot spot. However, I cant even assign a static IP as the DJI Remote keeps going back to a private DNS and randomizing the MAC. SO frustrated!
2022-1-15
TeddyBozeman
Westwind77 Posted at 1-15 18:42
See if you can use your hotspot to download the latest firmware; that fixed it for me!
2022-1-15
