DJI Susan
Hi bcharleson, we are sorry for the issues you encountered. Please help to isolate the issue.
For the vision system errors, may I know if the errors persist after taking off? If the errors only existed while the drone is on the ground/before takeoff, that is normal. When the aircraft is placed on the ground, vision sensors will automatically turn off to save power consumption. When the aircraft takes off, vision sensors will turn on. Please rest assured to use it.
For IMU and Gimbal calibration, please make sure to calibrate them on a flat surface. Try to restart the drone and check again. Please let me know if the errors existed frequently.
Regarding the gimbal issue, please be advised that Mavic 3 supports the gimbal axes lock feature: for more convenient storage, the gimbal axes will lock automatically after the aircraft is powered off and unlocked when it is powered on again. Please double confirm that if the issue exists after the drone is powered off, or if you are using the drone at operating temperature.
Hppe these provide you with some information.
