Warning ‘Camera storage speed low….’
2551 13 2021-11-22
Tegels
Flight distance : 5889249 ft
Since last week the proud owner of a Mavic Pro 3 Cine. The aircraft flies really great, unfortunately I regularly get a message 'Camera storage speed low. Backup file and format storage space'. I record in ProRes on the SSD. I tried formatting the SSD but that didn't help. I get the message especially when I make a Yaw movement with the device. I'm guessing it's a firmware issue? The recordings are okay and play back without any problems.... Who knows what to do, what can I do?
2021-11-22
Maxi3D
Flight distance : 307621 ft
You have a low speed Micro SD card in the slot. Use a U2 classification MicroSD card for this bird.
2021-11-22
JJB*
Flight distance : 12260774 ft
Maxi3D Posted at 11-22 12:46
....I record in ProRes on the SSD....
2021-11-22
Tegels
JJB* Posted at 11-22 12:48
Me too…….
2021-11-22
Visual Air
Flight distance : 2710115 ft
Like the OP said he has the Cine version with the ssd
2021-11-22
Geebax
The message is telling you that your SSD is too slow in write speed.
2021-11-22
JJB*
I don`t....
My reaction was on post#2, he did not really read your post....
2021-11-23
Tegels
Okay, I contacted the online DJI support. They said it is a known firmware issue and should be solved in the next firmware update. Nothing to worry about!
2021-11-23
Maxi3D
Tegels Posted at 11-23 04:53
Never mind. I need to read better.
2021-11-23
KlooGee
Flight distance : 16783757 ft
Yep, pretty sure this is a known issue with the firmware.  People are getting this on the Cine model when recording to the SSD.  But I'm also getting it in my base model Mavic 3 using a U3 card that is absolutely up to spec.  I get the error message, but don't see any negative artifacts in the video with playing them back.
2021-11-23
Tegels
Maxi3D Posted at 11-23 12:50
Oh, I see, that's quite reassuring. What should you do in the meantime with your $5000 drone that can't record footages? Did DJI offers any suggestions?
If you read my opening post well, you could have read that the recording files are fine....
Edit: you delete your reply
2021-11-23
Maxi3D
Tegels Posted at 11-23 12:54
Sorry.
2021-11-23
Tegels
Maxi3D Posted at 11-23 13:44
Sorry.
No problem!
2021-11-23
Patrick_D
Flight distance : 834465 ft
I had the same issue and could luckily find out that the files them selves were fine (until now).
It's simply a bad moment to be in a professional environment and your device suddenly comes up with messages like this! SSD operations are very sensitive to small failures (We had several SSD crashes in the past time) and as we have to offer reliability to our clients a PROBABLY fine working SSD/Firmware for my opinion does not belong in an expensive device with the nametag "cine".
Back to the SSD speed issue:
Have in mind everybody that the speed issue also effects the reading of the SSD! When we tried to copy the footage to a backup SSD with the official DJI USB-C Cable with maximum speed the Mavic SSD Drive was ejected several times both on a Mac and a PC. Only decreasing copy speed within the copy software helped to avoid the problem. So don't start your copy process and go to bed or to beer in good hope it will be finished fine in one attempt.
2021-11-26
