DJI Mic and DJI Pocket 2 compatibility
4553 9 2021-11-23
oddfellow
Flight distance : 14236 ft
Can the new DJI Mic me used with the Pocket 2 with the USB-c connection or does it still need the (awful) Mic Adapter?
I never purchased the combo kit. I just have the USB-c adapter from the first Pocket camera which I have stopped using due to too many audio failures.
2021-11-23
HGDC84
Finland
Certainly a question I would like to know the answer to, too, before buying the DJI Mic. Any insights from DJI or fellow forum members?
2021-11-23
DJI Stephen
Hello there. Good day and thank you for the inquiry. You can use DJI Mic with cameras, smartphones ( only Lightning & USB-C ports are supporte d), computers, DJI Action 2, and DJI OM 5. Thank you.
2021-11-23
oddfellow
DJI Stephen Posted at 11-23 19:03
So, to paraphrase.... NO. It will not work directly with the Pocket 2. Is that correct?
This seems like a very serious omission on DJI's part and is incredibly disappointing.
Is this compatibility expected in a future firmware update?
2021-11-24
HGDC84
Finland
Can it be used through the Do-It-All Handle's 3,5mm audio input/output connector? Or through the same handle's USB-C connector?
2021-11-24
djiuser_YDkq4WpUZGQT
Thailand
If you have the creator combo handle you can link the receiver to the pocket 2 by the 3.5mm cable. this way the audio from the dual mic set up is recorded with the video file
2022-5-19
Thailand
HGDC84 Posted at 2021-11-24 13:47
Yes by the 3.5 cable
2022-5-19
Thailand
I cant see how it would connect to the standard pocket 2
2022-5-19
HGDC84
Finland
djiuser_YDkq4WpUZGQT Posted at 5-19 21:54
I think you'd need the official Osmo Pocket 3,5mm to USB-C adapter for that, unless it supports connecting directly by the USB-C connector.
2022-5-20
HGDC84
Finland
Still waiting for an official DJI reply about the ability to use the DJI Mic with the Pocket 2 connecting directly with the DJi Mic's USB-C connector... is this a no-go or does it work/will it work later with a firmware update?
2022-5-24
