DarthSLR
Flight distance : 1846716 ft
Since my Mavic 3 Cine is currently en route for replacement, I'll be speaking theoretically...
Uploading via RC Pro directly to cloud is probably the best way in the field, if all you have some hotspot in shape of your smartphone.
However, if you're back at the office with a fast WiFi, or, better yet, Ethernet, your options improve drastically.
If you record on the SSD, your best option would be connecting the craft via fast cable to to your PC. Alternatively, with a strong WiFi, you can connect to a device, such as iPad, and use Files to access and then upload the files to the place of your choosing.
With a non-Cjne version, or, if you intentionally are using SD card, you can also extract the card and put it into a fast card reader.
Depending on the exact hardware you have, one method can be better than the other. Test and choose. |
