CemAygun
Turkey
Fishycomics Posted at 11-28 06:22
well lie about it, get burnt, and DJI Staff here won't reply to it they rather stay out ofit. Ever since the 90's three cameras came out they had Interpolated software enhanced, and still do. I doubt these 23Mp action camers are more than 5Mp
Unfortunately most of spec lies are "safe" ones, so you cannot take action (no pun intended) against the companies.
For instance they put a real 20+ megapixel sensor in a camera despite knowing that it would never reach that kind of definition with the given lens setup (due to diffraction limit). It does not work as intended, but it is there.
Quad Bayer sensors are another arguable batch, which actually have high megapixel sensors, anywhere between 48 to 108, but the color resolution is only 1/4th (1/9th in case of 108MP) of a standard sensor. Since color is always interpolated (albeit at a reasonable level) they can get away with whatever spec naming they like. Legally, the base sensor resolution is there. Even the term "Quad Bayer" is a disgrace as the Bayer filters in these sensors are actually "quarter" of a regular one. They can call it "Quad", which sounds higher, better, because there is 1 color filter for every 4 pixels.
So even if the final output is nothing like what it should be, since the advertised hardware exists in some form or another, you cannot do anything apart from shaming and boycotting these products...
Interpolated 4K is a different evil though... By the way if my memory serves me right, until Action 1 came around Gopro's maximum stabilized output was 2.7K, as that was about what was left after the crop. Starting with Hero 9 they don't have the this problem, at least on paper. |
