New DJI RSC 2 Firmware Released (11/30/2021)
4384 15 2021-11-29
DJI Support
Flight distance : 2408 ft
Overview
Date: 2021.11.30
Firmware:   v01.04.00.00
RavenEye Firmware: v01.03.00.30
DJI Ronin App iOS: v1.4.10
DJI Ronin App Android: v1.4.10
User Manual: v1.0
What’s New?
  • Added photo capture, video recording, camera settings, autofocus, and focus pull support for Panasonic GH5 M2 cameras with supported macro 4/3 mount lenses using Multi-Camera Control Cable (USB-C). To use autofocus on Panasonic GH5 M2, press halfway down on gimbal camera control button.
  • Added ActiveTrack for Panasonic G9, GH5S, BGH1, and GH5 M2 using Multi-Camera Control Cable (USB-C). Latest camera firmware version is required, which can be downloaded at https://av.jpn.support.panasonic ... download/index.html
  • Fixed issue: could not control some cameras after hot swapping camera control cable.
  • Optimized FPV mode settings.
Notes:
  • Motor parameters are reset after updating firmware. Make sure to autotune DJI RSC 2.
  • Make sure that the DJI Ronin app is the latest version when updating the firmware.
  • Update the firmware using the DJI Ronin app by connecting the DJI RSC 2 via Bluetooth. Do not disconnect the DJI Ronin app and DJI RSC 2 during the update process.
  • Update the firmware for the DJI RavenEye Image Transmission System using the DJI Ronin app by connecting the RavenEye via Wi-Fi. Do not disconnect the DJI Ronin app and DJI RavenEye Image Transmission System during the update process.
  • If DJI RSC 2 has a camera attached and is powered on while updating the firmware, make sure to protect the camera and lens as the motors will power off during the update.
  • If the firmware update fails, restart DJI RSC 2 and retry.
2021-11-29
Frontliner 2020
Philippines
thank you for the update...
2021-11-30
Montfrooij
Flight distance : 2560453 ft
Thanks for the update!
2021-11-30
Moshe.mmm
Flight distance : 1320098 ft
Israel
Montfrooij Posted at 11-30 03:00
What is the addition of active track to these camera means?
The same like with raven eye just without the raven eye ?
If so, how to use it? I have updated the camera to the latest firmware.
2021-12-1
Montfrooij
Moshe.mmm Posted at 12-1 10:31
I have no RSC2, so I can't help you, but I guess it will combine the feed from the camera with moving the head so it stays in the same spot.
2021-12-1
NailTimVideo
Russia
Thank you
FPV mode became more clear
2021-12-2
djiuser_nQrZK1PdhQAK
Croatia
This firmware feels awful.
On the last one, with Orbit Follow enabled, PF mode, speed set to 10, deadband to 3 - operating the thing felt almost like operating the glidecam. You could get really smooth and intuitive pan following.
You could easily walk around the subject and pan follow would work just great. Orbit shots felt perfect.
Now it is all jerky. Enabling Orbit Follow seems to do nothing!
With this firmware, on the pan axis you get around 20-30° of rotation before it moves like on sport mode. It feels awful.
On the firmware before you could rotate it 90° or more while walking and it would progressively move acordingly...
What is happening?
I've switched firmwares few times and can confirm that on the latest one pan axis just feels awful, no matter the settings..
2021-12-2
user21cde7e77f
Croatia
Please enable bluetooth shutter control for sony A7s iii. I have cheap gimbal for gopro and bluetooth shutter control is working.
2021-12-2
fans48abce45
Flight distance : 4284826 ft
djiuser_nQrZK1PdhQAK Posted at 12-2 15:09
I have the exactly same problem and I roll back the firmware too.
2021-12-3
Croatia
fans48abce45 Posted at 12-3 17:34
I really hope that they do something about it. It is almost unusable with this firmware...
2021-12-3
Eduqueen
Flight distance : 559308 ft
So as far as I can see you do not advise to update with this latest version.
Which firmware version is the one that works best?
2021-12-6
MKDP
Flight distance : 2613402 ft
I don't really use FPV mode personally, so the 'Optimized FPV mode settings' seem redundant for me. I see a few unhappy people about this FW. I really wanted the gimbal to charge my A6500 while in use....
2021-12-21
Croatia
DJI RS2 has the same firmware problem!!!
2021-12-21
Dong ZeYuan
Flight distance : 57060 ft
Thanks for sharing.
2021-12-21
bbvr
There is no Android DJI App for the Ronin RSC2 on the Google Play Store.
So then how to update the firmware?
2022-1-9
djiuser_5iYDN2mbuqcM
bbvr Posted at 1-9 18:03
The latest firmware (1.04.00 for the rsc-2  is pulled down for a while. According to the customer service they are optimizing it before they release it again. The app can be found at the dji download center. Search for ronin app.
2022-1-18
