New DJI RS 2 Firmware Released (11/30/2021)
5237 21 2021-11-30
DJI Support
Flight distance : 2408 ft
Overview
Date: 2021.11.30
Firmware: v01.05.00.00
RavenEye Firmware: v01.03.00.30
DJI Ronin Tethered Control Handle Firmware: v32.33
DJI Ronin App iOS: v1.4.10
DJI Ronin App Android: v1.4.10
User Manual: v1.0
What’s New?
  • Added photo capture, video recording, camera settings, autofocus, and focus pull support for Panasonic GH5 M2 cameras with supported macro 4/3 mount lenses using Multi-Camera Control Cable (USB-C). To use autofocus on Panasonic GH5 M2, press halfway down on gimbal camera control button.
  • Added video recording, camera settings, autofocus, and focus pull support for Panasonic BS1H cameras with supported L-mount lens using Multi-Camera Control Cable (USB-C). To use autofocus on Panasonic BS1H, press halfway down on gimbal camera control button.
  • Added ActiveTrack for Panasonic G9, GH5S, BGH1, BS1H, and GH5 M2 using Multi-Camera Control Cable (USB-C). Latest camera firmware version is required, which can be downloaded at https://av.jpn.support.panasonic ... download/index.html
  • Added photo capture, video recording, camera settings, autofocus, and focus pull support for Nikon Z9 cameras with supported Z-mount lens using Multi-Camera Control Cable (USB-C). To use autofocus on Nikon Z9, press halfway down on gimbal camera control button.
  • Fixed issue: could not control some cameras after hot swapping camera control cable.
  • Fixed issue: could not set follow speed when using Panasonic cameras with DJI Ronin RavenEye Transmission System.
  • Optimized FPV mode settings.
Notes:
  • Motor parameters are reset after updating firmware. Make sure to autotune DJI RS 2.
  • Make sure that the DJI Ronin app is the latest version when updating the firmware.
  • Update the firmware using the DJI Ronin app by connecting the DJI RS 2 via Bluetooth. Do not disconnect the DJI Ronin app and DJI RS 2 during the update process.
  • Update the firmware for the DJI RavenEye Image Transmission System using the DJI Ronin app by connecting the RavenEye via Wi-Fi. Do not disconnect the DJI Ronin app and DJI RavenEye Image Transmission System during the update process.
  • If DJI RS 2 has a camera attached and is powered on while updating the firmware, make sure to protect the camera and lens as the motors will power off during the update.
  • If the firmware update fails, restart DJI RS 2 and retry.
2021-11-30
Frontliner 2020
Philippines
thank you for the update...
2021-11-30
RUD_fr
2021-11-30
Montfrooij
Flight distance : 2560453 ft
Thanks for the information!
2021-11-30
Paulo Paulino
Flight distance : 2774265 ft
Portugal
I just test on my new GH5 II and works perfectly.
Now I only hope it also come an update for my old GH5.
2021-11-30
user21cde7e77f
Croatia
Please enable bluetooth shutter control for sony A in next firmware
2021-12-2
GeorgeGreek
Flight distance : 636050 ft
Greece
Thanks for the update!
2021-12-4
SubhanBaghirov
Flight distance : 34882 ft
Azerbaijan
hi i have rs2 and after last update pan speed is same at 5 and 100
2021-12-8
sky_makai
Flight distance : 3397539 ft
Just want to let you know @DJI, the new firmware made it so the RS2 speed and deadband settings don't work.  I had to downgrade the firmware.
2021-12-8
sky_makai
SubhanBaghirov Posted at 12-8 00:02
Same issue.  I just posted a comment about it.
2021-12-8
djiuser_K2YZ3AmH9o1b
I am having the exact same issue. How do you download older firmware? @dji please fix!
2021-12-13
Same. How do you install an older firmware?
2021-12-13
Indio
Flight distance : 303373 ft
Austria
in the app:
tap longer than 5 sec on firmware
2021-12-13
SubhanBaghirov
Azerbaijan
sky_makai Posted at 12-8 15:24
i went back to my old version everything is ok Thanks men
2021-12-16
djiuser_nQrZK1PdhQAK
Croatia
Same problem with the latest DJI RSC 2 firmware. Wtf is happening?
2021-12-21
Indio
Austria
back to the older one and fine
2021-12-21
Dong ZeYuan
Flight distance : 57060 ft
Thanks for sharing.
2021-12-21
djiuser_WZatOwABH6m3
Croatia
I really hope that they just didn't test it. On the other hand, I'm afraid that they will leave it like this and then release new RS3/RSC3 that will "fix" the problems...
2021-12-22
djiuser_8zeXtIMsRDIt
Russia
I have the same problem whith pan, it doesn’t work. Please update firmware
2021-12-29
skyandmethod
Flight distance : 2009590 ft
Ukraine
Same issue. Deadband and speed does not work as expected. Pan axis deadband setting does affect nothing! Going downgrade.
Test your bull... before release a lot of changes
2021-12-30
e1darie1
Flight distance : 1843084 ft
United Arab Emirates
looks like DJI done roll back, because latest update is v01.04.00.20
if you open Ronin app it will show you "new" update v01.04.00.20 and Firmware: v01.05.00.00 is removed!
2022-1-11
Rud
firmware 1.05
in menu, is the mode steadycam option enable? because when it is enable pan axis speed is modified (speed can't be change it follows you like it is locked). perhaps it is your problem so disable it and see if that resolve your problem. i found this option very usefull when we do very quick mouvement, When enable, we dont need push M button anymore to have same quick mouvements. To me everything run normally in firmware 1.05.
2022-1-17
